My OEM alloy's are finally black!
Old 06-16-2004 | 08:08 AM
  #41
sn0w_m0nkey's Avatar
nice job on the wheels!
how did they hold up to wheel weights being pounded on for balancing?
Old 06-16-2004 | 08:20 AM
  #42
rimpainter.com's Avatar
I sprayed mine with the tires mounted, so the weights were already in place. I prepped and sprayed over the weights as well. Touch up is really easy, if needed.
Old 06-16-2004 | 08:27 AM
  #43
COYOTA $x$'s Avatar
Did you consider/price out getting them powder-coated black ?
I would think that powder-coating would be prety durable in the long run as well ?
I think yours look better than the steel wheels.
Old 06-16-2004 | 08:31 AM
  #44
keisur's Avatar
where's the write-up Christian?
Old 06-16-2004 | 08:42 AM
  #45
I did consider that. They wanted $40/wheel pre-prepped, and $75/wheel if they prepped (blasted) them. They also wanted them for at least 3 days, and the tires would have to be taken off. You can see my dilemma.
This route worked out to around $30 total.
Old 06-16-2004 | 08:43 AM
  #46
It's coming! I swear.
Old 06-17-2004 | 04:46 AM
  #47
EDGE's Avatar
missed this thread, nice job did you do the inside of the rims or just the outside
Old 06-17-2004 | 05:33 AM
  #48
SLC Punk's Avatar
As soon as the temps go down a little I might get around to it.
As if that will ever happen in AZ! :pat:
Old 06-17-2004 | 06:00 AM
  #49
keisur's Avatar
Cool. it looks good. I may try this with my Pro Comp Xtreme Alloys.
Old 06-17-2004 | 09:18 AM
  #50
I just painted the outside (assuming you mean the "backside" by the discs and drums)
Old 06-17-2004 | 11:30 AM
  #51
EDGE's Avatar
I meant the inside, the part where if your washing your rims you can see the inside, that silver part their not clearcoated maybe some overspray from when they coat the outside but not the inside, the part that is visible if your standing close to the truck, not the back side that attaches to the hub
Old 06-17-2004 | 01:10 PM
  #52
keisur's Avatar
I believe he's Edge is asking about the "inside diameter" of the wheel.
Old 06-17-2004 | 02:05 PM
  #53
Hmmm, well either I am slow or we are just miscommunicating. No biggee. I painted everything you can see, facing the wheel, with the tire on. I did not spray on the backside. However, I did attempt to spray the outer lip as best I could, but that proved to be a bit tough because the stinkin tape would not stick in some places.
Let's just say, I could have done much better if the wheels were off the tires. However, you can only see the flaws up close.
Old 06-18-2004 | 11:20 AM
  #54
EDGE's Avatar
yes, thats what I meant, must of lost something cause I could not think of what it was
once again nice wheels, now do the truck in black
Old 06-19-2004 | 03:37 PM
  #55
tenfourtyeight's Avatar
I did my outlaw II's in flat black. Looks pretty cool. All I did was clean them, sand with some 300 grit, primer, then several coats of flat black paint. Touch-up for scratches takes less than five seconds.
Old 02-16-2005 | 12:26 AM
  #56
getitdone's Avatar
i plan on getting some crap rims at the junk yard and preping them with por 15. Do you think that will be stronger than other paint?
Old 02-16-2005 | 12:27 AM
  #57
getitdone's Avatar
by the way, how's the paint holding up christian?
Old 02-16-2005 | 05:55 AM
  #58
I don't know what por15 is
Again, its all about prep. So if you do it right, pretty much anything is going to stick. As for the paint on my rims...yes, it is holding up well. A couple periodic touch-ups have been in order, but for the most part they still look great. The lug nuts are most prone to chipping...but then again you can just touch those up too.
I would do this mod again in a second.
Old 02-16-2005 | 09:26 AM
  #59
AznSky's Avatar
I'm debating if I should follow in your footsteps again........ So you just painted them while they were on your truck?
Cuz my bumper is holding up real well.
Old 02-16-2005 | 10:05 AM
  #60
Actually, I pulled each one off and left the tire on. Ideally, you want the tire off. But that can be a real pain.
Do it Rob!!
