My Fogs are Dead
My Fogs are Dead
I've got power to the switch and I can hear the relay clicking, but no lights. Just happened out of the blue. Both bulbs appear good and the harness is hooked together well. I'm bummed
Any ideas as the to the problem would be helpful.
Thanks folks!
Thanks folks!
Thanks folks!
Thanks folks!
Matt
Sudden death
Sudden death usually means one of two things:
1) blew a fuse somewhere (don't forget ones that may be in-line as well as in a fuse box)
2) bad connection, usually a ground wire
If they are Hellas or aftermarket, check the connectors coming off the relay as they have a tendency to wiggle loose and then electrical tape them up to the relay so thye are sturdier.
Good luck!
Good luck!
zombie_barbarossa
10-02-2015 10:54 PM
