My cab WILL be SILENT!!!!
Doesn't quite work like that. The weight thing is not for actual horsepower. It comes from drag racing where it is said that losing 10lbs is LIKE adding 1 extra horsepower.
I used Peel & Seal all over the interior of my rig...best thing I've ever done...just for grins I used Dynomat in a part and used Peel & Seal in another and the results were exactly the same...just get some Peel & Seal, the weight didn't have any effect on my mileage...after the 33's it will take a big jump for me to really care enough about it. I'm still gettin about 14.
Fink
Fink
sound from the rear underside of truck? might it possibly be the exhaust pipe contacting the cross member? I had an older toy pickup that did that (granted the exhaust was moved slightly due to a minor traffic accident). It would rattle going over a jarring bump / hole.
Yeah, what Vince said has happened to me before too...one of my exhaust hangers somehow came loose and everytime I went over a bump I would hear a clunk coming from the rear of the rig...took it to my welding class and welded it back together and everything works fine now.
Fink
Fink
#25
Originally Posted by Yota4runner
Miles, was it worth it? Was the time put into the project worth the amount of sound deafening that took place?
#27
Originally Posted by 93ToyKid
Well thanks for all the replies guys. I'm not really interested in adding sound deadening material, the truck is insulated really well, and has the insulation blanket on the hood........it's actually quite quiet inside. What I'm asking is is there any way I can adjust the passenger seat. It shouldn't rattle like that. And as for the tin can noise, it just sounds like something is loose underneath the truck, but I don't know what. Thanks again.
#28
where do you get this "peel and seal" and how much was it?
Fink
Fink
#30
the rear clunk could be spare tire stuff???
like the chain or cable bouncing against the spare tire rim?
or it could be the exhaust lol..i'm sure my 4runner will make all kinds of rattles and noises when i take it for it's first drive =(
#33
i was looking to do this sound proofing or what not but these posts are old. so if i repost an existing subject i either get my post deleted or i revive an old post. sorry but its damned if i do damned if i dont. and camo this is not aimed at you but at the nature of the beast.
#34
Yotalaz personally I commend you for searching, some might not, but I think it is the better way to go. It lets people know that you are actually searching. Kudos. So, I guess you are only damned if you do, or is it don't?
#37
39 Thieves
01-06-2017 01:08 PM
JustMike
04-21-2016 07:08 PM
Badfish740
08-27-2015 06:38 AM
