my 4wd doesnt work?????
Old 09-14-2005, 05:19 PM
EWAYota's Avatar
I'm guessing that since it worked before and you haven't done any kind of work to any of the transfer case or differential, then its got to be a loose wire or vacuum hose somewhere. I'm not really sure where you need to start though.
Slestak75's Avatar
What do you say? I say embarrasment either way
Old 09-14-2005, 05:26 PM
EWAYota's Avatar
na, i've been pulled out before, and i've been the pulley. its just a part of the game. i got stuck in the mud hole a 74 bronco on 36's dug. had a 77 gmc on 36 tsl's try to pull me out, he got stuck in the mud. had to get the tow rig for the bronco, F350 down to where we were and pulled us out.
Old 09-14-2005, 05:27 PM
Slestak75's Avatar
I tried to 4wheel up mt everest but I couldnt get passed customs at norfolk navel base. I fear Ive lost my sanity
Old 09-14-2005, 05:32 PM
  #25
Slestak75's Avatar
But how bout this problem of mine? If I seem slightly iradic, It is because I am slightly intoxicated. Good thing Im pecking on this keyboard and not trying to find a hill to drive my toyota up hey?
Old 09-14-2005, 05:59 PM
  #26
callmej75's Avatar
This was a simple fix for me when mine wouldn't engage. Look on the passenger side fender under the hood and notice where the vacuum lines go through the fender to a canister. Well right there on the fender should be a little one way valve. Ok get in, start the truck, put it in 4wd and in park. Get out and pull the vacuum line off that one way valve....it should be a little round inline filter looking thing. you should have vacuum before the valve and after it. If not....the valve is faulty...but what I did with mine was blow through it and spit in it and instantly after hooking it up the light came on and 4wd was engaged.
ashersullivan88yota
01-18-2022 05:37 PM
mskalmus
05-28-2017 07:51 AM
Road Bull
10-10-2015 04:55 PM
cyclist231
07-07-2015 12:56 PM
Suprarossa
07-06-2015 05:21 AM
Quick Reply: my 4wd doesnt work?????
