my 05 has problems!!!
my 05 taco has problems!!!
I dont think the 4low and the rear diff lock work. The other day I was messing around on some dirt hills . anywas I became high centered and got stuck. I hit the diff lock button and the light kept flashing and the rear wheels never spun . When I shift into 4low the low light flashes and I hear a beeping noise and it never goes off . It also doesnt feel like its in a lower gear,am I doing something wrong? I have the auto 5spd if it maked a difference.
yeah, i had this issue the first time i went offroading ... you have to put it in neutral first, i think, and then shift it ... there should be a little card in the visor above your head about how to use it ...
just stop, put it in neutral, and then shift into 4lo. if it's flashing or beeping, then it's not engaged so try it again ... good luck!
ok so i tried it again in the street in front of my house and all is well, I did read the manual but it wasnt clear I think i was reading the part for a stick .Also it took a while for the rear diff to lock maybee cause it has never been used before . Oh well thanks for everyones help .
It is not recommended to engage 4 low and the rear diff lock on a dry paved road, only on a low traction surface, if you do it on a high traction surface, you risk damage from driveline bind. Also if the rear isn't locking try turning the vehicle (not on a high tractin surface), this will make the rear wheels turn at slighlty different speeds and allow the diff to "line up" and lock.
theking11863
03-19-2016 10:36 PM
