Muffler from another make?
Old 12-13-2004 | 05:01 PM
Chapman88SR5's Avatar
hey i have a friend who has a stock muffler from a subaru wrx, hes guna give it to me and i was wondering how you guys would think it would sound on my 22re? im just curious and im guna try it espesially since its free
Old 12-13-2004 | 05:05 PM
TACOMANATOR's Avatar
Should be fine, they are both four bangers-----as long as the piping is the same diameter.
Old 12-13-2004 | 05:06 PM
jimbo74's Avatar
i am sure that the piping is not the same...
Old 12-13-2004 | 05:08 PM
ha i just asked and he said the piping is 4inches
is that right?
Old 12-13-2004 | 05:10 PM
jimbo74's Avatar
its very possible.. the wrx is a turbocharged engine even not with the sti its still pushing out somewhere like 3 times the hp your 22re pushes
Old 12-13-2004 | 05:11 PM
so how would i get the muffler to fit my stock tubing?
Old 12-13-2004 | 05:12 PM
jimbo74's Avatar
with tubular adapters available at any autostore.. or ths shop doing the welding should have some laying around as well
Old 12-13-2004 | 05:15 PM
do u know how much it is for all new tubing or is it worth it
Old 12-13-2004 | 06:28 PM
turboale's Avatar
4"????
No way... stock?? If it is true, I wouldn't use it. Your going to have no torque what so ever. With a forced induction vehicle (espcially a turbo) the less backpressure the better. See, the turbo will provide all the backpressure you need on top of the fact taht the turbo is blasting as much air into the engine as possible, so the more backpressure you add on = powerloss. With our N/A trucks its quite opposite, not only are our engines designed for torque not high end hp they don't have that backpressure provided by the turbo. C'mon, you can get a muffler for under $50. Check 96Runner's sig, he has a setup installed for $50 or something like that.
As for tubing, I wouldn't say its worth it. I didn't do it. I figure I'd just keep it cheap til I S/C it and then it will be a little more worth it. Or if I get a rear bumper I will intagrate it so its protected from rocks as mine is already bent up from tellico. Though with the body lift it doesn't look too bad with it bent...
my .02
Old 12-13-2004 | 06:46 PM
i wasnt going to use the tubing on my 4runner... just the mufler
Old 12-13-2004 | 10:42 PM
jimbo74's Avatar
still the point is the inside is 4" and if you are going to run an small to large adapter to the muffler then a large to small adapter out of the muffler... its just dumb... serious... it wont give you the right backpressure becasue again ,its for a car thats a turbo and probably ppushes out almot 3 times your power numbers
Old 12-14-2004 | 08:45 AM
turboale's Avatar
Well, your going to pay at very least $20-30 to get the thing put in then another $20 to get your stock muffler put back in. By that point you could have gotten a good muffler.
Old 12-14-2004 | 08:54 AM
1987 street toy's Avatar
don't do it you will hate yourself i put a 2 1/2 inch raptor muffler on mine and it suck's!
okamikai
04-30-2018 11:19 PM
09-04-2015 10:27 AM
tj884Rdlx
08-28-2015 01:04 PM
toyoterferdayz
Diesel Swaps
07-27-2015 06:25 PM
HookahRoo
07-20-2015 08:06 PM
