mpg....where did it go??
I went through the same thing a while back... During the summer I drove quite a bit, probably about 50/50 city and highway and I was averaging about 20 MPG. I was getting about 300-330 miles per tank. Now I make much shorter trips, it's colder, and we have winter blend gas, and I'm getting around 15 MPG or around 240 miles per tank.
IMO, I think taking the shorter trips has had the largest effect on my mileage, cuz I started noticing a difference way before it started getting cold.
#27
im going to fill up tomorrow and ill post up what mileage im getting. right now im at 120 miles and the needle is on the 1/4 (first line) mark. im feeling depressed.
im hoping its something simple like the o2 sensor, but thats 100 bones out the window if im wrong.
#30
I'm having an issue with my mileage too and it's off by about 50 miles a tank and a couple of months ago my I had a CEL indicating TPS problem and I cleared the light and it's never come back on but I think I could still have a problem with it anyway but my mechanic did a full check on it and all the readings were correct and checked my other sensors and didn't find a problem.
I'm at a loss since I don't want to just replace things and still have bad MPGs.
#32
#33
#34
It does suck down a significant amount of gas when warming up... Mine can idle at up to 1500 RPM when I first start it up, but when it finally warms up it idles around 600. Basically I just have faced the fact that in the winter I'll see my MPG dive.
#35
You don't need to warm up the car for 10 or 15 minutes. In really cold weather, like less than 10 degrees F, it's reasonable to give the engine no more than a minute before driving. Otherwise, 15 seconds is fine for getting oil flowing.
When an engine is cold, the fuel mixture is enriched with more gas. As the engine warms up, less fuel is brought in relative to the amount of air. When the engine is idling, it really has a hard time warming up. So you spend a lot of time in the warm-up mode. Driving helps the engine warm up faster.
You should still take it easy when it's cold. Your tranmission fluid and differential fluids are cold, too. I've heard it takes about 10 minutes after your coolant has reached operating temperature before your engine oil is at full temperature.
Cut out the 10 to 15 minute warm up and I bet you'll see a big jump in gas mileage.
MadCityRich
MadCityRich
#36
i disagree. i think it takes more than just a minute if your truck has been sitting out all night in the cold before you drive it. if you let your truck oil get to a good operating temp, your oil will lubricate the enigne and you will be a happy camper.
after all theres a guage for oil temp. :]
#38
Oil lubricates at any temperature. The question is how well it flows. Cold oil is more viscous, meaning it's more resistive to flow. But if you use the right oil grade, there is no problem with lubrication. That's why you don't want to go with WOT with a cold engine. But normal driving is just fine.
A minute is plenty of warm up time.
MadCityRich
#39
ok filled up tonight. 11.13 gallons with 129 on the trip odo, for a whopping.....drumroll............11.59 mpg!!!
something is definately wrong, even with winter gas and healthy 15 min morning warmups.
