Modified Maglite mod!
I bought the Maglite clips at Home Depot for $4.18 including tax, and when I got home, I decided to only use one clip for the mod, not two. I attached it to the black crossbar on the bottom front of the driver seat. I think I saw someone else had done this here, but had used both clips. There really is no need to use both, as one holds it very securely. Of course this is the smaller D cell size Maglite, the larger one may require both clips.
I predrilled using an 9/64" metal bit, and using the clip as a template, then I used the screws that came in the package with the Maglite clips, and voila. The 9/64" bit was perfect for the included screws. It is totally out of the way, secure, and I have another clip for my other Maglite!
Re: maglite
Originally posted by rjm
mine is mounted with both clips on the passenger side of the center console.
maglite
mine is an 02. i mounted it has much foward as i could. you are correct- if i were to move the seat all the way foward, it would hit the maglite. but, i never need to have the seat all the way foward- if i do- i can just take the maglite out of it's clips-problem then solved!
TheBFA
02-15-2020 07:55 AM
voiddweller
53
02-01-2016 06:46 AM
