Moaning
Yes mine moans too @ 1800 rpm. I think its the fan clutch. Only does this when cold and only @ 1800 rpm. It does matter how fast i,m going , if I,m at 1800 rpm she moans untill shes at operating temperature.
BUMPing this for any new ideas/help?
The noise is still here, and I just did:
tranny flush
coolant flush
new timing belt and other belts (V, alt, ac)
oil change + oil filter + lube
air filter, fuel filter
new pcv valve
and triple dose of seafoam to get things cleaned out a bit.
The moaning is still there and under the same conditions.
Hot or cold, doesn't matter.
Off the gas - no moaning
on the gas lightly at low rpm - moans badly
on the gas hard - no moaning.
please please please post any other ideas. I feel the shlt is going to hit the fam sooner or later.
thanks
tranny flush
coolant flush
new pcv valve
thanks
See this thread...I am having a similar issue:
U joints???
Pinion Angle with respect to the differential angle???
https://www.yotatech.com/forums/f2/ome-lift-installed-driveshaft-vibration-51725/
U joints???
#25
U joints???
https://www.yotatech.com/forums/showthread.php?t=51725
U joints???
This was posted in your thread:
Originally Posted by lv4runner
Stephen, I'm on the same page as you. This vibration/humming sound didn't start until I put the OME stuff on.
Same here, and I am glad someone used the word 'Humming' since I thought I was the only one with the noise. Humming, moaning, all what I hear in my rig.
I will start to track that thread you have started to see where it takes you.
