Meth/Water injection on a turbocharged 5VZ
Old 01-04-2014 | 05:17 PM
Texas_Ace's Avatar
Originally Posted by Robb235
Time to bring this thread back from the dead.
Where are you all mounting your pumps, or planning on putting them? I've tapped the bottom of my washer fluid reservoir today, but not really sure where to mount the pump.
If you have a 4runner check the videos in my SIG, the latest one shows where I mounted mine.
Old 01-04-2014 | 05:30 PM
Robb235's Avatar
Yeah I saw that. It seems you mounted it to the side of your air box? In your video, it also appears that you put the fittings up top, above the electric motor. I'd rather keep fittings below the pump motor if I can. I tried doing it that way, but fittings conflict with power steering fluid reservoir.
Old 01-04-2014 | 05:55 PM
Texas_Ace's Avatar
That was the first mounting point, I just did that for testing as I didn't want to take the time to install it properly until I knew it was worth keeping installed.
The last video shows where I moved it to.
wberry85
05-17-2016 06:45 PM
RatOmeter
10-22-2015 04:17 PM
LCE_Performance
10-01-2015 02:03 PM
sonorn67
09-19-2015 06:39 PM
Papadeath
09-14-2015 11:26 PM
