Are metal tabs necessary?
Old 05-29-2004 | 06:11 AM
Tacoma Dude's Avatar
I would like to mount some lights on a section of metal tube that doesn't have any tabs welded on to it. Should I just go and find someone who will do that or are there any suggestions that are almost as stable and solid?
I kind of have the feeling that there really isn't but I figured I'd try anyway
Old 05-29-2004 | 06:30 AM
Hey, that's pretty cool - a bit pricey at $27 a pop though...
Old 05-29-2004 | 07:54 AM
SkyRat's Avatar
I used these straps to mount my license plate. They might be too flimsy to mount lights, but if you pick the right size they hang on very well.
Old 05-29-2004 | 08:23 AM
waskillywabbit's Avatar
Talking Mounts
You could also use the ARB tube mounts that many folks use to mount their CB to the ARB before they started putting the tabs on the ARB.
http://www.4by4connection.com/cbaccessories.html
Good luck!
Old 05-29-2004 | 08:25 AM
Corey's Avatar
Co-Founder/Administrator
Staff
How big is the tubing?
If around the size of a Yakima cross bar, you can use the Yakima Snap Arounds.
The hole for the bolt and plastic wingnut you can use for the light stud instead.
I test fitted a Hella 500 on my cross bar years ago before getting the Yakima Load Warrior light mount plates instead.
Old 05-29-2004 | 10:44 AM
George:
Do you have any close-ups or pics of those straps by themselves?
Brian:
How have those been holding up? That looks like a little friendlier solution.
Corey:
The width is about grille guard size, I dunno - 1.5"? That looks like it would be good but you have to slide it on via an open length, right?
Thanks guys, keep the suggestions coming, I appreciate it!
Old 05-29-2004 | 11:04 AM
Talking
Originally Posted by Tacoma Dude
Brian:
I don't personally have one as my ARB already had the new tabs, but I've seen several in person (don't remember who had them) and they look more than adequate to do the job if they'll hold on an antenna at high speed then I would think a light woudl be no problem. You could always put a small piece of rubber in there so it wouldn't slip.
I think both Corey and midiwall (Mark) use these for their CB antennas, so you might ask around for some other input, but I think they'd work fine from what I've seen of them.
Old 05-29-2004 | 02:09 PM
Corey's Avatar
Staff
Corey:
Nope, that is why they are called "Snap Arounds."
They open up so they can fit a Yakima round bar or a Thule square bar.
Open up, snap or slide on over the tubing.
Old 05-29-2004 | 02:30 PM
cool!
I may end up going that way then. Thanks guys!
ashamsuddin
17
07-22-2024 04:59 AM
gibbonsballer10
10-26-2023 08:13 AM
Dale Johnston
11
10-31-2015 11:22 PM
whiteyota93
09-29-2015 03:31 PM
sonorn67
09-19-2015 06:39 PM
