Magnaflow problems/questions!
Hey everyone. I just got the SS 5x8x18" Magnaflow installed (97 V6) I like everything about it except for a slight drone at around 1850rpm under load. I'm not sure what could be causing this resonance because other people here with the same muffler seem to have no drone problems. I even replaced the U-type clamps with SS T-bolt band clamps and it helped a bit with the noise.
I'm thinking of getting either the 5x8x24" or the 5x11x22" SS Magnaflows, but I am concered about those because they have a 2.5" inlet/outlet and I know that my pipes are 2.25". Would using these mufflers affect much? Thanks in advance!
Seems to me that you might be more susceptible to being annoyed by the droning than others might be. Certainly sounds like you've done what you can to help... when I first got mine installed I found that if I listened carefully enough with my radio off that I would be annoyed by the tire noise and the exhaust drone. Now I just love hearing it
its an aftermarket performance muffler... i liked the drone i had with mine... but im wierd like that.... i also love the hum of my tires....
a 2.5" will be fine, any place installing it will have adapters....
i welded a 5x8x18 and pretty much cleaned up my exhaust, replaced bolts, etc. and mine was making a weird noise too, come to find i had a small exhaust leak around the flange, but the magnaflows tend to resonate without the baffles in them
this may be a dumb question but i have heard that the magnaflow muffler sounds better than a flowmaster 40 series and has a deeper tone, therefor i want to put one on my taco with a 2.7l in it, exactly which magnaflow muffler do i need
i just sold the one that used to be on my truck.. it was the size listed above... not sure if it was stainless steel, but it did have a very shiny case.... i currently have a flowmaster 40, and the magnaflow did sound better.....
magnaflow recommends 2 1/2" dia 5x8x14, i put in a downey header with a 2 1/4" 5x8x18 muffler just to retain some back pressure, so far im pretty satisfied with it and im not even geared, but im thinking bout switching to a dynomax or something thats not freeflow
Maganaflow help here
http://pnw4runners.com/exhaust/exhaust.htm
Considering how bad my muffler was to begin with it is a huge improvement.
Thanks for the replies everyone! I tried that link a while ago already, but the 24 inch magnaflow sound clip doesn't play on my comp (I'm not sure why either). My main concern is if the 2.5 inch inlet/outlets on the longer mufflers will hinder performance. I read that when the diameter of the pipe increases, the gas will expand and cool causing it to slow down. If it cools where the muffler is then it is forced back to 2.25 inch piping wouldn't that be a big deal?
Quick question though... i've read on this forum somewhere that the 3.4 V6 4runner engine does need SOME back pressure. Is this correct? Since these mufflers are relatively freeflow. Is that not enough backpressure? Or if i stick with the stock 2.25 pipe should i be ok? I'm a mix of highway/city driving. So... i sort of need low and high end power. I dont want to loose either.
Aline- all engines require some backpressure. no back pressure usually can cause valves to burn out prematurely. so can an exhaust leak over time. I have heard of people running the larger 24" without much complaint. Have also seen some street cars with high cubes run 2 mufflers on each leg to quieten it down a bit.
Maybe this will help...
I upgraded from 265/70/16 to 265/75/16 and put in a 3" suspension lift. I was really starting to notice the lag in acceleration but after putting in the Magnaflow 18" I did notice some pep back in the gas. Now I can't tell you that it worked scientifically with any fancy shmancy graphs but I can tell you that if this set up was supposed to *hurt* performance than I definitely would have noticed.
Aline- you asked if the 3.4 needed some back pressure. I was only adding that all engines require backpressure. thats all
With that said, the factory 2.25 tubing should be optimum correct?
thanks
Originally Posted by Alin10123
Oh ok, i thought you were saying that since the magnaflow is a straight flow, that it wasn't enough back pressure. But i think since many people are running the magnaflows here, that the back pressure is adequate.
thanks
thanks
