In-Line Fuel Pump for 5VZ-FE
Old 02-07-2013 | 03:36 AM
AlexJet's Avatar
I'm using a fuel tank which does not have in-tank fuel pump.
To supply fuel for the 3.4 v6 (5VZ-FE) I'd need in-line fuel pump which can be mounted on the frame rail.
Does anyone knows what specs for the in-line fuel pump I should be looking for and what brand(s) and/or models will be suitable for fueling the Tacoma v6 engine.
What is OEM fuel pump flow rate and maximum pressure?
Old 02-08-2013 | 06:15 AM
Texas_Ace's Avatar
I would look into the Bosch 044, they are pretty reliable and will flow plenty for that engine unless you are fully building it and going turbo.
sandyota
02-04-2021 12:16 PM
09-04-2015 10:27 AM
TURBOrunnerNM
07-22-2015 12:01 PM
Fundy Rider
07-16-2015 02:35 AM
Tyler Cunningham
07-11-2015 11:18 AM
