Lime on windows -- solution?
Do any of you have lime deposits (the water spots that won't go away with windex or washing) on your windows? I do, and they're especially prevalent on the rear 5 windows. I've tried several things, all to no avail. Am I alone here or has anyone fought this battle before?
Zach
Zach
I had this same problem; we have very hard water here. Just dillute some vinegar with water and apply it with a paper towel. then dry it with another paper towel and go back over it with windex. It works great for me.
You might try mixing some washing soda or borax into your wash bucket before you wash your rig. Let the bucket stand for 30 min or so...especially if it's cold. The Ca++ ions should be precipitated out of the water and replaced with Na+ ions ending your problem with lime buildup.
Well the Ca (+2) is binding with something, and that's what is precipitating out, not just the ions right? What's the rxn for this? Is it ppting out CaCO3? Just curious, its been a long time...
I use RainX on those... Usually takes them right off. Sometimes you have to apply it twice, but it gets most anything off. Makes water fly off the window for the next two weeks as well.
-Byron
-Byron
Tom...
In the case of Borax (Sodium Tetraborate, Na2B4O7) you would precipitate out CaB4O7 or Calcium tetraborate. What would remain in solution would be Sodium Carbonate or Sodium Sulfate, depending on your water's chemistry. It should be safe to use on Aluminum also, but test it first.
Washing soda is Sodium Carbonate. Upon reviewing it, skip the washing soda. While it would appear to soften the water, it doesn't, it merely makes the water more basic. This would make the water "feel slippery" but not actually take the Ca2+ ions out of solution. It would probably harm your aluminum.
Originally posted by jharris2
This thread has gotten way too technical and is bringing back some not-so-pleasant memories.....
Acetic acid should do the trick- most metal salts precipitate out of water (forming metal hydroxides at high pH), acidic solutions will re-solubilize them. Just remember, if you're not part of the solution, you're part of the precipitate!
Chemist
Chemist
Hehe
First of all, thanks to everyone for the advice. I might try the vinegar, or maybe I'll ask my chemistry teacher (I'm in high school), if she knows what would take it off. The formula for lime is definately CaCO3 (calcium carbonate) then, right? Now I know you all won't believe this, but I actually like chemistry. I'm definately a math/science person, and I'm taking honors chemistry 1 as a junior. I plan to continue next year with A.P. chemistry, so wish me luck! And then I had a question for Mad Chemist: are you really a mad chemist?
Zach
Zach
Zach...
"Lime" is usually, but not necessarily always CaCO3. It's used pretty indiscriminately to describe any water deposits, whether they be carbonates, sulfates or any other ionic compounds. Whether your deposits are actually CaCO3 depends on the chemistry of your water supply. CaCO3 usually is found in surface & groundwaters that flow over/through limestone formations or unconsolidated limestone sediments. However, you'll also find a lot of sulfates & sulfides in those same waters.
Mild acids, of course will probably take the water spots off, just try to limit exposure of the acids to the paint, aluminum, iron, etc. Work the reations out yourself...you know the possible reactants....figure out the products. The reactions are usually double replacement. Then take it into your teacher for perusal.
