Lights for Radio Station and also Climate control out
I checked my fuses but can't figure out what is going on with the lights.
How can I check/replace the lights. Searched but couldn't find any guide for that section.
just took ownership of a 1996 limited and need to do some tweaks (lights, pass window, antenna etc).
Pull off the 4 knobs, then pry off the front face plate with a flat head screw driver, then replace the bulb with a #74. you can get the bulb from v-leds.com
did some searching but only found 2 people who had solved/attempted to solve by removing the unit and taking the bulb out to get it replaced. didn't see if they were successful or not so i sent some pms to them.
jasonty
41
12-23-2018 01:00 PM
kirkrunner
07-27-2015 07:59 PM
rushw
07-18-2015 01:46 PM
