LED Bulb in Shifter...
Old 01-20-2008 | 11:47 AM
Nate08's Avatar
Just did the white conversion to mine too!
Old 01-20-2008 | 11:51 AM
Mr_Martinez1982's Avatar
those gauges are SUPA nice, i might have to look into it, thanks for the pics.
Old 01-20-2008 | 11:56 AM
ozziesironmanoffroad's Avatar
howd you do the led in the glovebox? or did it already have a light in there? mine doesnt, but i want a light for the glovebox.. info on that?
Old 01-20-2008 | 12:15 PM
CLin9383's Avatar
pics? or did you just do the gauges? I plan on doing the whole thing from gauges, to climate to glove box. i should have it by next week. i will put pics up once i finish
Old 01-20-2008 | 12:29 PM
  #25
doctorcarta's Avatar
where do you purchase the LED lights that will replace the stock ones? thanks
Old 01-20-2008 | 12:34 PM
  #26
Nate08's Avatar
AutoZone has them for $9.99 for a pack of 2.
Old 01-20-2008 | 03:01 PM
  #27
Fo_SheeZy's Avatar
The answers are already in this thread?? All it takes is a little reading..
Old 01-20-2008 | 10:03 PM
  #28
Drsuesss's Avatar
The glove box light had a regular bulb in it. I just replaced it with a 74 size led that I had. Im not sure why yours doesnt have one, ozzie?
As for the A/C button, I couldnt see how to get the bulb out of the little switch to put the bulb in? Any help there would be appreciated. Theres a little green in my radio already too, so i was thinking about just leaving it the way it is? Thought?
Also, I want to do the dome lights and they have the 3175 bulb with leds, but i noticed that alot of guys are going the oznium 16 or 25 led bulb route. If I dont want too much light, but enough to look cool, what would you guys recommend? I think the actual 3175 bulb comes with 2 or 3 leds, where 25 might be a bit much? Thanks!
Old 01-21-2008 | 12:58 AM
  #29
pdyebrasil's Avatar
The a/c switch has a small bulb that unscrews from the bottom. You'll see it. The new neo-wedge LED just screws right in. I replaced both the A/C switch and the defroster.
I used the following bulbs from V-LEDs:
I used 4; 2 for the map lights and one in each dome. The dome lights aren't really bright, but look "cool" and they're as bright as normal bulbs, but the map lights are very bright.
Old 01-21-2008 | 08:06 AM
  #30
Drsuesss's Avatar
Thanks for the info.
Do the mods ever end? Haha. Thanks again!
RyanJ989
11
04-07-2021 10:41 AM
4banginRunner
11-13-2015 06:23 AM
voiddweller
09-29-2015 12:21 AM
Scotttekoch
09-28-2015 11:30 PM
dropzone
09-13-2015 12:18 PM
