Leaf spring question
Old 06-26-2003 | 06:55 PM
oly884's Avatar
Guest
I know that this should go in the off road section, but this also goes for on road too.
I just got some new leaf springs for my truck today. I ordered some skyjacker 4" leafs, problem is they are 6". I thought that I could take out one of the 3 main leafs, the smaller one, and have around 4" of lift, and a lot better articulation. I know that the springs are DESIGNED to have all leafs in it, but is it dangerious at all to do this? thanks, David
Old 06-26-2003 | 09:02 PM
oly884's Avatar
Guest
bump
Old 06-26-2003 | 09:06 PM
Cebby's Avatar
How did you measure 6"? The weight of the truck should take them down a bit. Can't help you on pulling leaves out of the spring packs.
Old 06-26-2003 | 09:07 PM
oly884's Avatar
Guest
I just bought them, and they have the part # that say's they are 6"
Old 06-26-2003 | 09:11 PM
Cebby's Avatar
My bad, I thought you were measuring them off the truck.
Old 06-26-2003 | 09:13 PM
oly884's Avatar
Guest
Ah, I see, not a problem. I'm mainly just wondering if there is any danger in doing this.
Old 06-27-2003 | 06:20 PM
oly884's Avatar
Guest
bump
Old 06-27-2003 | 07:21 PM
joez's Avatar
nope, no danger, but it wont lower you truck. it will bring it down about a half and inch, and give a much flexier suspension out back, with a better ride.
if you are going to do this, remove the leaf 2nd from bottom. dont take out a main leaf, these are the strength of the spring. or you could take out the leaf below the mains, that would prolly work better, but might make them a litle too soft
nvdesertrunner
05-11-2020 09:18 PM
Griff
93-98 T100s (Build-Up Section)
09-23-2015 11:11 PM
shisha1999
09-21-2015 09:22 PM
88sasturbotoy
08-11-2015 02:56 AM
Nickdigg
07-07-2015 07:04 AM
