LC Wheels on 3rd gen.
Awsome. I will be joining the club on Tues or Wed. I can tell you that you got a smoking deal on those wheels. I paid a lot more but am hoping they are in near perfect condition and they came with the funky lugs and caps. Tires are already here(BFG MT 285's)
I just like the look of factory rims.
Yeah, those wheels do look great. I got my appointment this Wednesday to put them on with my new tires. I will take plenty of pictures. (I also have scheduled another alignment --- my last one which was only about a month ago is already out.)
Post some pics when you get yours too !
nice, looks sweet dude, I've been trying to pick up a set for a while now, if you don't mind me asking, where did you pick them up at? I trie ih8mud.com but I havent seen a set come up there in a while now.
#25
JHupp- I posted an ad about 2-3 months ago looking for LC wheels...I think I got my hit from Ih8mud.com from a guy who had his wheels hiding in a corner of a garage for awhile...He was very cool with me and let them go for a great price. They came from California. My ad sat for about a month before I got any response.
Dexter- I think the silver look will match my trim alot better than white or black. If I had black bumpers, and no Limited silver flares then I would consider it...but I am keeping them original for the flowwwwwww......
Cheers! I plan on polishing them tomorrow.
#26
I just repainted most of my frame and rear axle. Makes a huge difference. I also wired up some reverse lights and removed my speaker box and spare tire (I couldn't stand how the spare looked undernieth). I am planning on moving my spare into the back cargo area with a mount which will be fabbed up hopefully by a friend (if he has time). I flipped my cargo mat upside down so the rubber is exposed and should resist stains, etc.
My LC wheels are going on tomorrow!!!
A few pics from today.
#27
Did you just take out a rattle can and go to town? Are there any areas to be careful around? I'd love to freshen up my undercarriage. Let me know how you did it.
4Peanut
#28
I crawled under with a flat head screw driver and hard wire brush and chipped away the rust that bubbled under a few areas on my pumpkin, axle, etc. I bought the more expensive paint that was about 4.50 a can (Rust preventor, etc) I used gloss black because I feel that with a smooth glossy surface, things tend not to stick as much when compared to flat black.
I was careful not to spray on any lube points, shocks, etc... I just sprayed away with about 2-3 coats. Make sure you use a high pressure hose to knock off any mud or winter sludge before you paint.
Good luck.
Good luck.
#29
#30
#32
Looks awsome.
Repainted my center caps last night and picked up the 5th 285 for the spare tire. I am going to try to get all 5 mounted and balanced today after work.
Seems like the valve stems are closer to the edge of the rim than on the 5star rims. I am going to ask for the shortest v stems I can get at the tire shop.
Hope I have some pics to show tonight!
#33
What air pressure are you running in your 285/75/16's ?
I have a 265/75/16 for a spare right now... is that good enough or is it bad to run a smaller tire if needed?
What type of paint and color did you use on your center caps... how did you prep them, etc.
#34
Wow, that looks great. I have come to the conclusion that the LC wheels look good as long as you have good lift and big tires. There's a 3rd gen right by my work w/ LC wheels and no lift w/ stock sized tires. It just looks OK.
Now Bamachem, Fink, Roofgoof, etc., the LC wheels look HARD!!!!
#35
Looks awesome ROOFGOOF!
What brand of paint and what color are folks using to match the factory color on the center caps? I need to paint a few centercaps to match a set of Limited five stars.
4Peanut
4Peanut
#36
4Peanut,
I am going to the store soon and take a center cap with me...I plan on "sampling" silver/grey colors until I match something close . I'll post something if I find a brand/color.
Cheers.
Cheers.
#38
OK...I am in the process of getting these caps back to looking mint. Here is my process so far.
I sanded down the center caps using 220 sandpaper. Cleaned them off using water and allowed to dry. I then used the following:
PRIMER WHITE and ALUMINUM spray color from the local Home Depot.
PRIMED 2 light coats
This is how they looked before the process.
Comparision between stock color (Limited wheel cap vs. my new painted LC cap) pretty close.... I will go back with a paint marker or small brush and paint in the Toyota symbol at some point.
To be continued --- hopefully they will look good with the wheels. I will probally put a total of 2-3 coats of aluminum color on.
#40
Thanks! I am going to see how the caps look on my wheels...if they don't match up well, I am thinking about stripping them again and perhaps paint them black with silver yota logo ???
