Late Model Parts List - Certainly We Can Do Better !!!
3rd Gen and Tacoma Trasfercase shift base gasket: 36345-35050
3rd Gen and Tacoma Trasfercase shift lever boot, small, rubber, lower: 33555-35190
Guest
Posts: n/a
DOWNEY
Pre-Charger - wrap for K&N filter on FIPK: 18038
__________________________________________________ _______________
TOYOTA
3rd Gen roof rack rail - Outer Skid Strip: 00278-96042
Fuel Sender Gauge Assembly - from TSB: 832011
*includes: *fuel send assy - gage: 83320-35590
*fuel sub-assy - tube: 77203-35461
*fuel suction - gasket: 77169-60010
BILSTEIN
3rd gen rear shocks: BE5-2451
TOYOTA
BILSTEIN
#25
I found the Toyota starter rebuild kit packages I got when I fixed mine. Starter problems pop up here from time to time, this is almost always the solution.
Repair service kit: 28226-54340
Starter kit:28226-72010
Got 'em both for under $20 shipped.
This thread, or a link to it should be in the tech/writeup section permanently.
Hopefully new people will get to see this now and keep it going.
#26
For the 2nd generation guys, this is what i've got.
1992 4Runner Parts:
Front suspension – ball joint – upper – RH 43360-39085
Front suspension – ball joint – upper – LH 43350-39085
Front suspension – ball joint – lower – RH 43330-39315
Front suspension – ball joint – lower – LH 43340-39245
Front wheel bearing – washer 90215-42025
Front wheel bearing – star washer 90214-42030
Front wheel bearing – seal 90311-66001
Front wheel bearing – outer 90368-49084
Front wheel bearing – inner 90368-45087
Front wheel – inner dust-cover seal 90313-93002
Brakes – master cylinder kit 04493-60280 / 04493-25060
Brakes – master cylinder reservoir seal x 2 47255-16010
Front brakes caliper – seal kit 04479-35010
Front brakes – ventilated disc 43512-35200
Front brakes – pads 04465-35040
Front brakes – anti-rattle spring 47748-30013
Rear brakes – cylinder kit 04906-35100
Transmission – filler plug 90341-18006
Transmission – filler plug washer 90430-18008
Transmission – shift lever bush 33548-31010
Transmission – shift lever seat 33505-35020
Chain transfer box – outer flange seal 90311-41008 (59 OD x 41 ID)
Chain transfer box – inner flange seal x 2 90312-23001 (1¼" OD x 23 ID)
Chain transfer box – outer flange seal 90311-41007 (61 OD x 41 ID)
Clutch – master cylinder kit 04311-35070
Clutch – pedal pivot pin 90249-08018
Clutch – pedal pivot pin bush 90386-08002
Propeller shaft – u-joint 29 OD x 52 Circlip to Circlip (Inner circlip)
Steering – stop bolt plastic cap 45619-36010
Steering – pitman arm 45401-35230
Steering – idler arm 45490-39375
Steering – idler arm bushes 90385-18068
Steering – tie rod end – inner 45406-39185
Steering – tie rod end – outer 45046-39385
Power steering box – service kit 04445-35110
Power steering box – input shaft seal 32 OD x 19 ID x 7 TH (High pressure)
Front 7.5” diff – RH inner flange seal 90311-35032
Front 7.5” diff – RH inner flange dust cover 41336-22010
Front 7.5” diff – RH inner drive shaft snap ring 90521-29002
Rear 8” diff – collapsible spacer 41231-40011
Rear 8” diff – pinion seal 90311-38130 (74 OD x 38 ID x 11 TH)
Rear 8” diff – main bearing x 2 17887R + 17831R
Rear 8” diff – pinion inner large bearing 070803C (35KC802)
Rear 8” diff – pinion outer small bearing 90366-30022 (30306C)
Rear axle housing – outer seal 70 OD x 50 ID x 10 TH
Rear interior seat – hinge cover 71629-89105
Cup holder 55620-89103
Rear window – LH bottom rail 69907-35010
Rear window – RH bottom rail 69907-35020
Rear window – bottom rail rubber x 2 69971-35020
Rear window – motor complete 69801-89122
Viscous fan coupling – fluid x 3 08816-03001
Voltage regulator – external 27700-72030
#27
Coil Spring Compressor, used to change the springs or shocks on 3rd Gen 4Runner:
Harbor Freight: ITEM 3980-3VGA ($10.99)
This is the good one.
#31
"All Thread" replacement bolt for the tension adjuster on the drive belt pulleys. You can't order just the threaded bolt, but this is the same bolt.
88446-35030
88446-35030
#32
Here's a good one...
Light Bulb for 3rd Gen Ash Tray: 90981-11014 S043 Bulb $2.40
So, I know you are thinking why??? Because it was burned out. My wife thinks I am crazy too...
30306c, 4335039085, 4549039375, 4561936010, 6980189122, 9021442030, 9024908018, 9031141007, arm, ball, bearing, idler, joint, part, toyota
