Late Model Parts List - Certainly We Can Do Better !!!
Come on boys show me the LOVE !!!
Toyota 3rd Gen Part numbers:
Upper ball rubber boot: 43324-39015
Rear Diff, Tranny & T-case low profile drain plug w/magnet: 90341-18021
Gasket for above drain plug: 90430-18008
Outer Tie Rod - Right: 45046-39335
Outer Tie Rod - Left: 45047-39215
Toyota Bolts for shackle hangers: 91642-81235
Manual Tranny, Transfer Case Shift Knob: 36303-35140-CO
Sequoia Transfer Case knob, Used for Marlin Cralwer front case :36303-34030
1999, 4WD, V6, 16" wheel, front coil, left: 48131-35350
1999, 4WD, V6, 16" wheel, front coil, right: 48131-35400
Outter dust seal front axle shaft: 90304-80002
Front shock, Rubber Isolator Ring: 48609-35010
Front shock, Upper Retainer: 90948-02161
Extended rear breather nipple: 90404-51319
Extended rear breather valve: 90930-03136
Tacoma Manual Hub, Gasket Free Wheel: 43531-60010
Tacoma Manual Hub, Gasket Front Axle: 43422-60060
Tacoma Manual Hub, Cone Washer: 42323-60010
Tacoma Manual Hub, Hub Body Nut: 90170-08036
Tacoma Manual Hub, Hub Body Washer: 90201-08042
Tacoma Manual Hub, Cover Bolt with Washer: 91641-80616
Tacoma Manual Hub, Open center Spindle: 43502-04030
Tacoma Manual Hub, Open center Spindle Nut: 43521-35010
Tacoma Manual Hub, Sealed Bearing: 90369-54001
Tacoma Manual Hub, Hub Stud: 90080-11282
1st Crossmember, Left Side Bracket: 51026-35020
1st Crossmember, Right Side Bracket: 51025-35020
4WD Center Mount/Manual Tranny: 12371-07020
Base Model Antenna, whip, black: 86309-AA040
Base Model Antenna Mounting Base: 86300-35090
Clutch Pedal Bushing: 90389-05017
__________________________________________________ _____
Off-Road Solutions:
Axle shaft, 4Runner manual hub kit: ORS-4RAX001
Outter CV joint manual hub kit: ORS-TCV001
Revtek:
Aluminum top spacers: TOE-2
Studs: STD-6
Phone: 1-877-LIFT-TOY (543-8869)
ARB:
Old Man Emu, rear 3rd Gen coil trim packer: OME80PF10
Blue line "trail" repair splice/coupler: ARB170206
Energy Suspension:
Steering rack poly bushings: 8.10101G
Dynomax:
Super Turbo Hemi, 2.25" offset: 17747
Show Your Yotatech Pride !!!
Off-Road Solutions:
Revtek:
Studs: STD-6
ARB:
Energy Suspension:
Dynomax:
Toyota 8" diff electric locker:
Complete V6 Electric locking 3rd member:
- 4.56 ratio -> :41110-3D010
- 4.30 ratio -> :41110-3D080
- 4.10 ratio -> :41110-3D030
New locker diff. gasket: 42181-60050
Longer diff. studs 111mm (2 required): 90116-08330
Diff. Lock ECU: 89533-35070
Diff. Wiring Harness: 82127-35100
RR DIFF LOCK switch: 84725-35010
1998 4Runner
ASCO/Aisin Seiki Clutch Master Cylinder: 31410-35310 (I3000-55036) ( www.thepartsbin.com )
ASCO/Aisin Seiki Clutch Slave Cylinder: 31470-35120 (I3010-54125) ( www.thepartsbin.com )
This is all I got handy...
I hope you feel the LOVE!
Fender Well Grommets - Part No. 90189-06028
I've used all sorts of nuts/bolts etc. but haven't kept track of part no.s...
I fell the LOVE, keep it coming !!!
1999-2002 Headlights:
Right: 81110-35320
Left: 81150-35300
1999-2000 Grill (chrome): 53111-35460
1999-2000 Emblem: 75311-35090
Anyone know the part numbers to put 2001-2002 tail lights on a 1996-2000?
Right: 81110-35320
Left: 81150-35300
Right: 81110-35320
Left: 81150-35300
Right: 81110-35320
Left: 81150-35300
driver side 8156035200
not when i put mine in. took out the old ones, plugged in the new ones..took all of 20 minutes. no problems since..
8155535210 passenger tail wire harness
8155535240 driver tail wire harness
i did not get these when i installed mine. i am not sure if they are neccessary but like i said, i just took the old ones off and plugged in the new ones..somone else chime in here??
Warn Receiver Shackle Bracket - p/n 29312
Parts for driver side "Oh sh$t" handle
Screw - 90159-60254
Grip Assy - 74610-16010-E3
Plug, Assi - 74617-16010-E7
Plug, Brea - 90930-03136
Union - 90404-51319
Driver side front axle boot - 04438-35060
Cobra 18WX ST II CB radio (fits perfectly in lower DIN) - p/n 480-315-P-001
Windshield wiper insert - 85214-YZZD4 , 85214-YZZD3
Screw - 90159-60254
Union - 90404-51319
All great numbers to have, lets see some more LOVE !!! I need some love tonight, for the next 3 hours I get to dance with an ARC Stick welder..........
Max Green told me a year ago learn to stick weld first, I am. It’s not easy. I have Oxy-Acetylene down as well as the popular MIG.
Post some Part numbers while I light myself on fire, again......
Originally Posted by TechWrench
Steve; A little off topic, but where did you get the avatar pic. It brings back some OLD memories for me. I was drinking Schaefer about when you were born (illegally of course) 0 . But some time after I went in the service, they moved the brewery and it was never the same again.
sschaefer, what the heck are you doing? Did I miss something? Are you bulding a beast?
These part numbers with get your 01 tails/harnesses.
81550-35240 - Right
81560-35200 - Left
When you order them from the dealer you get a new wiring harness and new bulbs with them. The new bulbs fit the new smaller sockets. The bulbs are also more realible. The old ones used to burn out quick, pre 01 owners will vouch for this.
Install write-up with pics of harness, etc. found here:
http://www.toyotaoffroad.net/jnburtman/Pictures.html
81550-35240 - Right
81560-35200 - Left
