knocking/rattle noise
Old 06-19-2010 | 03:33 PM
sis004runner's Avatar
my sister has a 00 4runner 2wd v6 and when your crank it you hear a deep knock/rattle noise and its the same noise when you hit bumps on the road. any body expereince this? sounds like its on the passenger side. thanks
Old 06-19-2010 | 03:41 PM
fireteacher's Avatar
motor mount?
Old 06-19-2010 | 03:46 PM
brian2sun's Avatar
Sway bar bushing/mount?
Old 06-19-2010 | 03:55 PM
im thinking that too. i noticed when it was up hill in a angle spot idleing andd backing down it was makeing that noise but if the 4runner level it wont make the rattle noise i idleing.
Old 06-19-2010 | 09:17 PM
RockyMtRunner's Avatar
I had a clanking sound under the same conditions you describe. My problem turned out to be the end of the exhaust pipe, located behind the passenger rear wheel. I had bent that section of pipe upwards while coming off a rock. It was bent far enough to bounce against the end of a frame-bolt located above and near the end of the pipe. Whenever the pipe shook and bounced a little bit, like hitting a bump or starting the engine, it clanked upward against the bottom of the bolt. I found the problem by pulling the pipe down and letting it snap up--clanking loudly, just like the noise I was hearing.
I bought a hard rubber stopper at ACE hardware, sawed it to fit, drilled a shallow hole in the top to cup the end of the bolt, had my wife step on the pipe to hold it down while I slipped the stopper between bolt and pipe, wife let go, and the upward pressure of the pipe held the cushioning stopper in place. No clanking! The first stopper lasted 9 months, exhaust heat and all. I just put in a new stopper to go another 9 months.
Old 07-21-2010 | 09:19 PM
sis004runner, did you ever find the cause of your noise?
My clanking noise came back a few days ago, and I found that the replacement stopper from the solution described above had worn/melted thru already. Many hours of 4lo wheeling during hot days apparently took their toll. So today I put in a new stopper but didn't saw any off the end so it will last longer. I took some pics to show how the stopper stops my clanking noise, for a few months at least. Cheaper than a new exhaust pipe assembly, which is what a muffler shop told me was the only solution.
Old rubber stopper burned thru and pipe started clanking on bolt again.
Here is the new stopper with a shallow hole drilled in for the end of the bolt.
Here is the new stopper in place and stopping my clanking.
Old 07-24-2010 | 10:23 PM
dave_mcmillan's Avatar
Thanks for the help...I have been wondering where the squeek was coming from..makes perfect sense.
zytra
01-24-2019 04:16 PM
Davebarbier
11-03-2015 04:28 PM
zombie_barbarossa
10-02-2015 11:54 PM
JPV
09-28-2015 04:15 PM
