keyless beep
Originally Posted by SLC Punk
Yep the beep is pretty annoying. Mine only works 1/2 of the time and I can't figure out whats wrong with the little churper.
Originally Posted by IamaFan
Did you get a double-chirp after holding the unlock button down for a few seconds? I don't know the exact amount of time that you need to hold it down.
In my owners manual is says that window down is 3 beeps.
#25
Thank you for these posts. I thought my piezo chirper was broken on my 3rd gen, but it turns out that for some reason the default for mine is piezo defeat on which means no piezo. So I did the steps and bam! I know when my alarm is armed/disarmed in the sun. Thanks guys
#26
Originally Posted by 4-RUNNIN' FREAK
Yes, I did. Lock is one beep - Unlock is two beeps -- and window down is a 3 second beep.
#27
Originally Posted by Bob_98SR5
SLC and SC:
i have the same problem. someone at the dealership told me that it is because the battery is weak.
bob
bob
The battery in my 4Runner is good, so I don't think its that...
Originally Posted by TOYJZX100
damn, checked it again and it stopped, i hooked it to the batt and it was the chirper again, imma shop for siren tomorrow, or ill borrow the one in my pickup.
#28
[/QUOTE]Did you ever get the siren hooked up? How does that work?[/QUOTE]
when you connect the chirper to a power source it will beep untill the power is cut off. just like the siren. it will sound when u put power. the Alarm ECU will send surges of power to make it beep. yes i did try the siren thing, but since the surges put out by the RS3000 Ecu is longer than the aftermarket ECU the siren came with, the alarm sounds different, i kinda like it. my problem is the door ajar warning. the chirper will make a long beep if a door was open. when u use a siren it will sound like a car alarm that went off.
#30
What battery, the car battery or the remote battery?
i think you guys are definitely on the right track w/ regards to the piezo buzzer thing giving up the ghost.
bob
#31
guys,
i did a quick search on "piezo buzzers" and this is what i found:
http://www.buzzersdirect.com/?src=ov...OVMTC=standard
a possible source for you guys willing to modify the buzzer.
bbo
bbo
#32
guys,
bbo
bbo
#33
-------For reference------------
2000 4Runner, my keyless remote has Unluck, Lock, Window Down buttons.
How to adjust beep volume:
1) Open drivers door
2) Hold Unlock button until you hear another double chirp
3) Press Lock to increase voume, Window Down to decease volume
4) Release Unlock button to confirm volume
#35
isnt this a violation to bring dead thread back up???
beep beep on the 99+, i believe. i know sport package have it.
go get that part and install inline w/ a relay. there should be a wire at the steering wheel collumn, green/red-horn(-), thats being tapped to.
wire it in this fashion:
85:wire from horn
86: 12v+ fused
30: 12v+ fused
87: to new beep beep
of course to ground the other leg of the new beep beep.
85:wire from horn
86: 12v+ fused
30: 12v+ fused
#36
Nice Pic profuse007! That stunning, crisp picture has amazing detail. Whoever took that pic, must be a pro! Oh wait...it was me. (haha, just goofing around w/ you profuse007.)
Looks like you found the old write-up where I removed my Buzzer on my '02 Sport. I personally cannot stand the chrip, so I removed it and threw it away. (didn't think anybody would actually won't one.) Here's the whole thread if anyone needs it though.
Hope it helps: HOW TO DISABLE KEYLESS ENTRY
PNW94Runner
09-29-2015 02:55 PM
