Just replaced valvecover gaskets
Good job on doing the head gaskets yourself.
Judging from the amount of rust on the engine components it looks like you live some place warm and dry.
I use Castrol GTX 10W-30. I have torn down engines that ran Castrol and they were always clean. It took about 3 hours to do both sides. The passenger side is easy. You just take the intake tubing off. The driver's side requires removal of the upper intake. It comes off in 2 pieces.
I have 73,943 miles. I remember cause I just did an oil change LOL.
I live in San Antonio and the previous owner lived in Houston, so it rarely sees any salt. I may take it to Chicago this year though.
Nice!!
I have some pretty bad oil leakage right now, and am going to start from the top, and work my way down since there is just so much oil, I have no idea where its starting. It looks like its up there though.
I run Castrol GTX (10w-30) as well, I've always ran it, and its been great. I had close to 300k on my last 4runner. I switched to Synthetics and decided I to switch back to dyno.
I did mine at 140k and my engine was nice and clean like that too. I use the 5w-30 oil from our dealership (I think it's Unical 76 brand) and a Toyota filter and change it every 3-5k miles. It took about 2 hours to and is not that hard to do. I changed the PCV valve while I was at it too.
yeah it is like $6.99. The only thing to watch for is on the driver's side there is a wiring harnes that is inside a plastic housing. It runs behind the timing cover up across the valve cover and sits on top of the valve cover. When I pulling the valve cover off, you have to move that harness out of the way. The plastic was brittle and shattered into the head. I spent an hour checking to make sure there were no fragments in the engine. Best way to avoid this is to wrap the entire plastic housing in electrical tape before removing the valve cover.
They do become very brittle over time so it does pay to wrap them in tape first.
09-04-2015 09:27 AM
