Just got 2003 4runner manuals if anyone needs anything
Old 02-19-2003 | 03:24 PM
impulsebrklyn's Avatar
Hey all just got Volume 1 & 2 for the 2003 4runner, need for find volume 3 and whats in it.
Volume 1
Preparation
Specifications
Diagnostics
Volume 2
Engine
Chassis
Body
Maintance
If anyone needs anything specific ill be happy for scan a few pages for you. I plan on scanning the pages for disasembly of the interior. ANyeon need anything else?
PS anyone know the size of the front and back speakers. Im assuming the fronts are 6 3/4 what about the back?????
Old 02-19-2003 | 03:32 PM
EDGE's Avatar
Where did you get it and how much did it cost you cause I was gonna buy a Service manual from Toyota, so what you are saying is it is 3 seperate books/volumes
Old 02-19-2003 | 04:47 PM
i paid 105 for the first two, ( i didnt know it was a 4 volume set I thought i was getting all of them) from what i have seen the third is much smaller and the 4th is just new features or something
here is a link someone has a full set there selling on ebay
http://cgi.ebay.com/ws/eBayISAPI.dll...&category=1132
what did they ask for them at the dealer??
jcmanuals1@yahoo.com is the email address from where i purchased mine
Old 02-19-2003 | 06:54 PM
Chris in Boise's Avatar
There's a constant little rattle noise I hear coming from BETWEEN the overhead console (where my HomeLink buttons, drop-down sunglasses pocket, and front seat lights are) and the windshield.
It sounds like a wire tapping against the side of the console.
Anyway, do your manuals explain how to remove the console? I'd love to be able to get in there with some strips of foam rubber to quiet things down.
Thanks!
Old 02-19-2003 | 07:11 PM
Good Times's Avatar
impulsebrklyn:
funny how i got the first 2 vol's from the same guy too!
i didn't know there was another 2 more vol's... dang!
but i think the other 2 vol's are for the v6 model since going thru the first 2 vol's it has nothing on the v6.
I think for all the v8 members, the first 2 vol's should be fine.
I've found everything I need so far just having the 2 volumes, so I won't be looking for the other 2...
Lance
Old 02-19-2003 | 08:02 PM
Good times that funny, i wish i knew for sure what the 3rd and 4th covered though hehe plus i have a v6
Chris in Boise give me alittle ill hopefully have them up in a few hours for you
Old 02-19-2003 | 08:28 PM
BT17R's Avatar
Thanks for the offer to be the 4th Gen Reference Librarian! I'll probably need the help at some point, but so far no worries.
Old 02-19-2003 | 08:29 PM
JGage's Avatar
If you could tell me how to turn off the DRL I would be indebted to you !!!
gage1911@bellsouth.net
Old 02-19-2003 | 08:30 PM
chris to boise here are the links
http://www.clarkson.edu/~calisec/tc442/uploads/1.jpg
http://www.clarkson.edu/~calisec/tc442/uploads/2.jpg
Jgage ill look these damn books are 4 inches thick but i should find it. By the way what is DRL?? would probably help to find it
Old 02-19-2003 | 08:53 PM
JGage's Avatar
Daytime Running Lights... I got screwed and had to get that option. My deal er wants $75 to turn them off.
It's like driving around with your parking lights on.
Old 02-19-2003 | 08:54 PM
lol ok ill take a look
Old 02-19-2003 | 08:56 PM
EDGE's Avatar
DRL = Daytime Running Lamps
Old 02-19-2003 | 09:21 PM
here is a dumb response before i even look why dont you just remove the bulbs?? or are the same lights also used for something else?
Im searching the isnt much info on this but i have found that there is DRL Relay no i just need to locate it. If it was altered to always off you should be able to disable it. Anyone got any input?
Old 02-19-2003 | 09:55 PM
Ok i cant find much ive gone through just about everything sorry
Old 02-19-2003 | 10:18 PM
BT17R's Avatar
Yeah, I posted awhile back to remove the plug connector going into the DRL relay. I THINK it's the aluminum-looking finned cube about 3" X 2" X 1" sitting behind the main fusebox and in front of the master cylinder. Question is, will that also disable the directionals that use the same bulb? Too lazy to try it myself, but believe it'll work.
Old 02-19-2003 | 10:50 PM
if that hole circuit is removed like you say the turning signal will be disabled as well here is the diagram below of the circuit
this is the circuit that seems to control the turn signals and drl
If im thinking correcting there should be a constant power feed to the drl relay. If you could find this source that completes the drl switch and disconnect it, you should be able to disable the drl and still have the turn signals work. Your gonna need a voltmeter, some trial and error and some time to do this. You need to find the circuit connection that is only powered when the car is on and that is only part of the drl. Another option would to make your circuit like the one without the drl installed
http://www.clarkson.edu/~calisec/tc442/uploads/drla.jpg
http://www.clarkson.edu/~calisec/tc442/uploads/drlb.jpg
Location of the drl relay
http://www.clarkson.edu/~calisec/tc442/uploads/drlc.jpg
Old 02-20-2003 | 07:49 AM
JGage's Avatar
Thanks I'll try it out when I get time. I appreciate you taking the time to look.
Heck, the local dealer doesn't even know... They said they would have to fax Toyota. They thought it was in the wiring harness though.
Old 02-20-2003 | 11:23 AM
impulsebrklyn, thank you very much for posting those diagrams for me!
Old 02-20-2003 | 06:31 PM
darkstar's Avatar
impulsebrklyn, Could you scan the instructions to remove the radio unit please.
Mark
Old 02-20-2003 | 06:49 PM
Good Times's Avatar
darkstar:
the radio is easy to remove....
but if you want to change it you're gonna have to get a head unit adapter because the stock unit is abit wider than the aftermarket single din or double din...
http://www.americaninternational.net/
These guys just released the new 03 radio install kit... I just ordered from them directly this morning and should have it by tomorrow! hopefully I'll finish the install and have some pix up for all of ya!
Basically:
1: remove center console - 2 parts where the shifter is located... all of em use clips - just give it a nice pull and it'll pop off
2: remove driver side panel attached to radio console( 2 clips only)
3: remove screw found behind center pocket under a/c control
4: pop out a/c unit (4 clips - 2 on top 2 on bottom) just give it a nice pull... (was scary at first but easy and won't break anything)
5: pull entire front center panel (silver piece that covers radio/ac etc etc)
6: radio is attached via 4 screws - 2 on bottom - 2 on side
7: remove radio
8: make sure u have the AI install kit to install radio w/
9: reattach everything n you're done!
PS: hopefully impulsebrklyn will have the pix up for ya for some idea on where the clips are if you're abit hesitant. I gave it a firm pull on every part that's attached and it all popped out w/o any damage to the clips. If you've played around cars b4 then you won't have any problems !
I hope to install my amp in the back passenger panel... some cutting n pasting will be required but i'll figure it out!
Lance
