JDM engine help!!!!
Old 02-06-2015 | 03:52 PM
traxxi2003's Avatar
JDM engine help!!!!
I'm swapping my 97 4Runner v6 for a newer JDM 5VZE. My question is: on the JDM motor, the oil filter and oil cooler location are interchanged, filter toward back of motor & oil cooler located where US made trucks have the filter, front side. I cannot change thee around because the bolt for the cooler is to long and the cooler does not seal well enough. With bolt all the way in, I can still spin the cooler around. Would it hurt anything if I leave the filter and cooler on the same location as they were installed on the JDM motor? I only asked because I had to change the oil pickup tube and oil pan since they were also different from my old US motor .
More importantly, will the lubrication be affected in any way by having the filter in the back, but the oil pickup on the front of the motor?
Old 02-08-2015 | 07:22 AM
aowRS's Avatar
Why not shorten the bolt in question?
Andreas
Old 02-20-2015 | 01:20 PM
Pozi's Avatar
Andreas
This is exactly what I did when I replaced my engine with a JDM. Additionally part of the shank had to be ground down but it worked perfectly. I removed the oil cooler that was originally on my engine.
snosurfer
3.4 Swaps
08-15-2024 03:11 AM
tobylab
01-18-2016 08:06 PM
tobylab
07-12-2015 01:53 PM
madxman21
07-09-2015 11:26 AM
