It's christmas...S/C
Super Charge, not Santa Clause.
Well i'm looking for something to make my 4runner more enjoyable to drive(more power). I'm not looking for smokin high performance. Just a bit more life out of her would be nice. I've got 154k miles on it.
This thread is really here because looking for someone to tell me "That's too many miles, you'll blow the engine." so I can change my mind and get the dodge diesel. But for now I'd rather s/c and keep the yota for a few more years and 3 grand is alot cheaper than 38 grand. Any advice anyone?
Toyotas last a long time. The mileage is somewhat irrelevant. if you take care of it it could be in excellent condition still. if someone doesnt take care of there car then that mileage would be equivelant to over 200k miles, if they take care of it, then it is likely to withstand the boost. However, If you are unsure, you can buy my Engine and Supercharger on eBay that has only 84k miles on it. I only want $3000 for it complete with everything. I will guarantee the mileage in any way possible. It is still in the vehicle.
http://cgi.ebay.com/ebaymotors/ws/eB...191050852&rd=1
I put mine on at 163k miles and just broke 171k with no problems. I did perform all recommended maintenance beforehand, and my motor is running better than ever. TRD supercharger, URD fuel mods, maybe a clutch, or if you have an autotrans, mods to handle that power. If the motor is healthy and you've taken care of it, you shouldn't have any problems. Just make sure to do a compression test and leak down if necessary (compression numbers aren't up to spec) before you commit. If you do commit to it, it will be *critical* that you run it right, and don't run lean or ping/detonate...then you will destroy your motor.
IMHO it was well worth the investment. The power increase will turn your 3.4L into a whole different beast. Down the road, I'd rather buy a new motor than buy another vehicle.
There are a lot of old S/C threads on here, 4x4Wire, and Tacoma Territory that talk about the ping issue.
No it does not but High RPM lean-out and High-Gear/Low-RPM ping are the two biggest issues you'll see. When I had my S/C on, I had the HG/LR ping problem. I was running the TRD S/C as it came out of the box with the addition of a TRD tranny cooler. I could have fixed it with the URD upgrades but decided not to spend the extra coin and pulled the S/C after a few years.
The moral to the story is if you are going to do the S/C, do the appropriate fuel mods also.
I'm guessing that eliminating any ping and keeping the a/f mixture correct is what the urd tuner is all about. I'm not looking to get all gear head with this thing, just want a boost. I'm tired of down shifting on every small hill, not interested in beating the 4runner next to me to the next red light. I do plan on the trd trans cooler. Does lean & ping only occur at the high rpms where the stock fuel system can't keep up, or does it occur based on throttle position?
To be safe, yeah I'd go with atleast a 7th, but I've also heard from plenty of people on the forums that run the TRD supercharger by itself and haven't had any problems. Again, just do plenty of research before committing.
Thanks for the info folks
I think yall have established some fuel mods are necessary for it to run not necessarily correctly, but to avoid problems. I'll definitely do one of the two. Next i'll have to figure out which one is best for my needs. I know about the octane increase need, that's pretty much a given any time you up compression.
