Intermittent starting on 3rd gen
Originally Posted by FilthyRich
My wife's 99 SR5 has 99k miles. Is up to date on ALL service work. It has not been wheeled in a long time--no mud or anything.
It currently has a 3 year old Interstate battery. However, the last week when you go to start it--nothing. THe lights work, but nothing. Not turning over, no click of the starter. Do that about 3-4 times and it starts. OR other times it will not start right up, like the battery is not fully charged.
I have not had the battery tested.
I was wondering if anyone else has ever experienced the same issue
Good Luck!
Ok seems like the contacts are the problem. Time to test the battery, inspect all fuses, battery terminals and pull the starter. Of course it is raining today
#25
FWIW, starter contacts from Roger took me 1-hour total to install. I have a 1" BL though; I hear it is more difficult to pull a starter on a non-body lifted Runner.
My 96 had the exact same issue (only it would click once when the ignition was turned to "START." Repeated ON --> START --> ON --> START combinations would eventually start it.
When I pulled the old contacts, I could clearly see the problem. $20 job.
#26
Eric, something else to try in the meantime... When mine "does this", I found that if I hold the key in the START position for a few seconds, it will eventually turn over. That's not healthy though - what's happening is that you're running current through the contacts without the starter turning and that'll cause a good bit of heat to generated.
06-01-2021 01:51 PM
Steezy96yota
07-06-2015 10:00 AM
