interchangeability of ifs third 2nd/3rd gen truck?
Old 05-14-2005 | 04:59 PM
rivercat's Avatar
i know nothing about the vaccum accuated front diff found in so many of our trucks, but a friend of mine blew his gears up so... will an ifs third member out of an '86 truck with manuel locking hubs go into a '91 truck with the vaccum accuated diff? just the third member and they're both 4.10's
thanks
Old 05-14-2005 | 07:44 PM
93ToyKid's Avatar
How did he blow a set of 4.10s up? Are you talking just swapping out the gears, or the entire center section? Yes, they are interchangeable, but you won't have the vacuum-actuated diff using the old third member. Which is fine, as long as you swap in a set of manual hubs. Did it on my 89...
Old 05-15-2005 | 10:57 AM
rivercat's Avatar
that's what we we're thinking, i wasn't sure if the vac. actuated stuff was in the pumkin or.... thanks
Old 05-15-2005 | 11:42 AM
kyle_22r's Avatar
'86-95 should all swap if im not mistaken
Old 05-16-2005 | 09:21 AM
mastacox's Avatar
thanks
The vacuum actuated part, that is off to the right... You should be able to chang the stuff out in the carrier. Make sure and check the backlash and pinion depth though, it might be slightly off when you change it...
Old 05-21-2005 | 11:05 AM
rivercat's Avatar
thanks for the help guys, we didn't want to mess with the inturnals at all so we found someone to trade with
AustinTaco
08-22-2022 11:45 AM
Daneums
06-29-2015 07:38 AM
Ott47
06-26-2015 06:21 PM
Bamripzit
06-20-2015 05:53 AM
Chooch
06-19-2015 04:05 PM
