Installing the CB
Installing the CB
I just recently went out and bought a CB radio.. I was just wondering how everyone else hooked theirs up? Where did you put the ground/power wires etc....
Thanks guys
Dan
Thanks guys
Dan
Hey Dan, how is the weather up there in Canada? Pretty cold, colder I bet than here. I do not have a CB, but I do have an emergency scanner. I use it for the fire co. I installed mine right under the headunit for the radio. You should have an empty pocket in there. I don't know if yours will fit, but mine did. All I did was cut the plastic and it is flush with the head unit. It really does look almost stock. I ran my power wire to the fuse box and tied it in with the ACC(essories) fuse. This works great because it does not drain the battery. I hooked the ground wire to the metal frame that holds the stereo. There are several factory ground wires there and I am sure that you can tie yours in with them. Goodluck. I am sure that others can get you some pictures, but I hope that this helps in the mean time. :fireman:
As usual.. thanks guys... and corey, i still drool over the look of your 4runner :eek:
PS... it is kinda cold up here. In Southern BC its not that bad, but as you head east (Alberta,Saskatchewan) It gets pretty bad.
punks_is_4x4
08-21-2015 01:35 PM
Esibnitsud
07-30-2015 08:19 PM
