Increased Idle on 3.0
I have noticed that past weeks that when the truck is warmed and idling in park the rpms where in the 800-1000 range normal for my rig is 700-800 rpms and now tonite after sitting at a drive thru window waiting for my food the idle was around 1250 in park. I found a few possible answers while doing a search. But i want to pick the brains of the ppl here a little bit more.
Originally Posted by AgRunner06
I just found 3 vacuum leaks that contributed to my high idle. Also try cleaning the throttle body.
Originally Posted by FireFighter
I cleaned the TB last month but i will try doing that again.Maybe a seafoam treatment is in order. As far as checking for vacuum leaks whats the best way to find them
and i think there was a thread here a few days ago where a guys idle was doing similar stuff like yours and it turned out to be either a bad or misadjusted TPS, i cant remember which one
hmmm interesting....
I cleaned my throttle body very carefully with a rag sprayed with TB cleaner only...
My hot idle went from about 700 to about 900 rpm idle...Cold warm up idle is 1200-1300 as expected.
Originally Posted by uxb101
mine was doing the same thing and i cleaned the tb with tb cleaner couple days later my tps was shot had to change it costed $200 Canadian so watch where you spray that cleaner ,ive heard people taking the tps off then cleaning the tb i will next time i clean mine
In case you didn't know, the TPS is a PITA to adjust. It took me and another person to get mine right. Just leave it on there and watch were you spray.
How in the world did you get TB cleaner on the TPS?
In case you didn't know, the TPS is a PITA to adjust. It to me and another person to get mine right. Just leave it on there and watch were you spray.
i did the afm mod but i did not change my timing do you advance the timing after changing the afm?
Well 10 degrees BTDC is ok I think, a lot of people use 12 and run premium and gain a little boost in performance.
LOL.....If i remember correctly mine is sitting at 15 or 17 or some ungodly ammount of advance and I've never touched it....I'll probably back it off to about 12 when I do the timing belt/water pump/idler. No pinging oddly enough...
ZONAYODA
07-13-2015 07:17 PM
