Idle Screw 95 Taco
Isnt it near the front right of the cylinders? I wish I had a digital comera I would just snap ya one but I dont until the 25th. Should only need a flathead for it. Why you turnin up the idle?
https://www.yotatech.com/forums/f2/idle-high-heater-weird-problem-42152/
Right here. had allmost the same problem
Is the A/C on or off? The idle screw is on the throttle body. Adjust it first with the A/C off, then with the A/C on. It should idle between 700 and 1000 rpm either way. By the way, there is a separate screw for the A/C idle rpm.
