Idle Mixture screw on '93' 4Runner???
![Question](https://www.yotatech.com/forums/images/icons/icon5.gif)
Now I really feel like a "Newbie" backyard mechanic.
I can't find the damn screw!
Haynes has a pencil diagram and says to flip off the cap and adjust as necessary. But I can't find no @$#!* cap! :pat:
I need help guys, if you have a pic of the area with a finger pointing to the "cap" where the screw is I'd really appreciate it.
My wife is really on my ass for this one!lol![spank](https://www.yotatech.com/forums/images/smilies/spank.gif)
I thank you all!!!![cheers](https://www.yotatech.com/forums/images/smilies/cheers.gif)
HAL>
![banghead](https://www.yotatech.com/forums/images/smilies/banghead.gif)
I thank you all!!!
HAL>
Here ya go. Fresh from the digicam
I forget which way increases it, but it happens very sudden when you turn the screw.
This is assuming you have the V6. When I had my '90 truck with the 22RE, it was the same setup, just different location.
It should still be in the same place though close to the plenum.
![grin](https://www.yotatech.com/forums/images/smilies/grin.gif)
![bowdown](https://www.yotatech.com/forums/images/smilies/bowdown.gif)
Damn Corey, you sure you don't have some sort of Yota blood running through your veins???
![bounce](https://www.yotatech.com/forums/images/smilies/bounce.gif)
Thanks.
BTW, are those factory plug wires or an upgrade? And what are those wire mesh hoses, does the wire mesh help or is this for looks?
Nice and clean, mind if I have lunch on your engine?!?
![bigok](https://www.yotatech.com/forums/images/smilies/bigok.gif)
All of this wrenching is to make sure I don't need tranny work done.... I'm losing power big time, never had the HG replaced, and I don't have a compression tester to find out. Maybe an inspection from the Yota stdealer is in order!:cry:
Hal>
Thanks Hal
I am glad you like our Yota site here in our little corner of cyberspace.
The wires are factory Toyota. Put 'em on last year sometime.
I was not sure how old the ones where that were on it, so I felt it was wise to change them.
They come with the wire looms attached if I remember, and were a snap to put on.
I went with Toy ones again as when I had my '90 Toyota truck I had put on an aftermarket ignition from Jacobs.
Good ignition system, crappy wires it did come with.
They broke down awfully fast and gave me a high reading on resistance.
I had the dealer back then replace them and the rig ran way better afterwards.
The sleeving on the engine bay I picked up a kit from my local Schuck's Auto parts:
It turned out OK, they just slip over your stock hoses. If I were to do it again, I might do as the Butnut did and go with the blue stuff he put on his hoses. It looks trick.
My engine bay is do for a wash. I'll have to hunt for that stuff that Jason uses.
I use the Foaming Engine Brite stuff that you can get almost anywhere, but I'd like to try that CR2 I think it is called.
I'd run your VIN # by your Toyota dealer and see if you are still qualified for the head gasket campaign.
Mine were done at 116K before I got the rig. They put a whole new short block in for the owner.
Corey
![Wink](https://www.yotatech.com/forums/images/smilies/wink.gif)
![](http://www.pnw4runners.net/tando/mod12.jpg)
![](http://www.pnw4runners.net/tando/mod12a.jpg)
Corey
skoti89
07-06-2015 07:45 PM
Jnkml
07-06-2015 01:20 PM
