I need a tool
Originally Posted by SpikeStrip
Use an SST to compress the tensioner idler:
Here's where to get one:
http://www.etoolcart.com/index.asp?P...ROD&ProdID=110
It's worth the 40 bux. Save you hours and lots of @!%$&*!!
Found it cheaper: Same tool too.
http://www.sjdiscounttools.com/sch97300.html
Good luck.
Good luck.
found one on ebay, worked great. thanks for the help. i was successful. not bad for my first time, however i'm not too sure i got the crank bolt back on as tight as recommended.
Originally Posted by bigacuralvr
ok, so you can get the bolt OFF the starter way, but how do you torque that to 212ft/lb?? Thats my question. I fabbed up a piece of steel, with 2 bolts and a center hole...Worked perfectly!!
any chance you'll make another one? if so, how much would you charge?
#25
Well, it took me an hour or so to make that piece...so I'll have to see if I can round it up (we're in the process of moving). I bought the big daddy torque wrench at sears. It was like $150, or so...but well worth the extra money!!
Brett
Brett
#26
Originally Posted by MTL_4runner
Make absolutely sure you got that back on tight enough because you can seriously damage the crankshaft if it comes loose during engine operation.
https://www.yotatech.com/forums/f116/lesson-learned-pics-76293/
RobotMoose
02-22-2020 07:44 AM
