I need help to clear 285s for cheap
2-3 inches should do it just fine. The rear is tricky because of the door. Us 2 door folk don't worry too much about that. Chop it, and be done. If you cut enough, you can get 35s under there. Still might rub the rear by the door though.
A 285 is 1.2" taller than a 265, therefore only .6" taller on the radius, and only 3/4" wider, so if you trim it wont need to be much, and probally only on the pinch weld...
#25
uh, no one has mentioned anything about the upper control arm. does no one have a problem with 285's bulging and hitting those? also i have to dissagree with the statement about the spacer lift not allowing for larger tires, i rubbed occationally with 265 75s on stock susp but when i did the spacer lift i never rubbed any where period
live4soccer7
05-11-2016 06:52 PM
JookUpVandetti
09-30-2015 08:58 AM
charlie_fong
09-27-2015 10:06 PM
