hydraulic brake booster and MC question
Old 11-03-2009 | 08:07 PM
SWPERIC's Avatar
How often does your brake booster kick on?
specifically for a 2002 4runner limited.
next Q if it is turning on more then it should, could the master cylinder be leaking inside itself?
had my gf help me bleed my brake over 9 months ago and im pretty sure she put the pedal to the floor. now every time i hear the brake booster go off, i cant help but imagine that she busted a seal in the MC. is there any way to check this?
Thank you YT.
Old 11-04-2009 | 02:03 PM
SWPERIC's Avatar
bump please
Old 11-04-2009 | 02:20 PM
hross14's Avatar
Huh-- you mean the ABS pump. I couldnt tell you but i havent heard of them going bad either. Do the pedals feel fine? Does it stop and the ABS work correctly? If the answers are yes--its probably in your head
Old 11-04-2009 | 05:30 PM
eric-the-red's Avatar
In my 01, which is the same as your 02, it goes on often. Almost every time I use the brakes.
Old 11-04-2009 | 06:21 PM
SWPERIC's Avatar
thank you both!
fountain
12-31-2015 07:08 AM
CanRunner
07-20-2015 02:29 PM
Johntom240
7
07-13-2015 01:18 AM
87turboPA
07-12-2015 08:49 AM
87turboPA
07-09-2015 06:58 AM
