how to take the dash off?
HU Removal How-To: (For 2000+ 4WD 4Runner)
1. Pull e-Brake Up
2. Put transmission in N
3. Remove Transfer Case Selector Knob
4. Grab rear-most portion of the transmission trim (where the TCS boot meets the trim). Pull up. Remove the rest of the way. There are 4 clips, 1 on each cornor of that piece.
5. Remove Ash-Tray and Cig Lighter.
6. Grab LowerMost portion of the dash. Pull. Work your way around. When you get to the top, be careful, as there is wiring. Unplug the 4 connectors. Leave the wiring at the bottom. Put the dash piece in the passenger footwell.
7. The HU is 4 screws, which can be removed with a screwdriver. Youre going to need the brackets on the side of your OEM HU to mount the A-Market HU.
Tips on reinstallation:
1. When you reconect the wire harnesses at the top, watch where they go. There are 4 harnesses, but 5 plugs. the Black harness fits into 2 spots, the clock plug, and a dummy. If you plug it into the dummy, your clock wont work. The dummy is the lower one of the two. You dont want to use that.
1. Pull e-Brake Up
i did, 47 results and none address the lights for the temp display. i will add do it and then i can post the results. probably easy, just haven't the time to do it.
should post my own ? too
![spank](https://www.yotatech.com/forums/images/smilies/spank.gif)
kawazx636
10-06-2021 03:03 PM
TheBFA
02-15-2020 06:55 AM
zombie_barbarossa
10-02-2015 10:54 PM
FS[PacNorWest]: 1987 4Runner SAS, 22RE, 5Spd, Dual Cases, etc
toyotasaurus
09-24-2015 03:30 PM
