how to remove overload leaf
From: Nor Cal. between sac and tahoo in the foothills. a little place called amador county
im doing the chevy swap right now. i cant figure out how to get the overload leaf off the chevy springs. when you spin the nut there is a circular cap that spins with it. there is no way to stop the circular cap from spinning.
VEry good idea to put some stout clamps on the springs before you do that. Some spring packs pop apart with enough force to seriously mess you up.
If you are talking about the center pin/bolt holding the spring pack together, a pair of vise grips works well, as mentioned above. Just grab the round end of the center pin with them.
thank you i got some vice clamps and it worked fantastic.
next question: how can i get the original leafs out of the shackle/hanger? i have tried hitting it with a mallet, and alos tried prying the other side w/ a huge screwdriver. neither of which worked at all. ideas?
See the last Q&A topic in last January's Toyota Trails Truck Tech colum:
http://www.4crawler.com/4x4/TLCA_Tru...ech.04.01.html
anyone else have any opinions on how to get that bolt out?
Perhaps you could clarify what you are having trouble with. It sounded like you were having trouble removing the bolt from the spring hanger, but apparently it is something else.
Jcrawl94
10
10-24-2015 05:34 PM
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
08-11-2015 02:56 AM
