How much heat can the headlights take?
What constitutes a "high beam?"
Paul,
You said that you wired some driving lights to your high beam switch. Good idea, but does this qualify as a "high beam?" I'm sure you pointed them well, but what will the State really accept as a "high beam?" Would one have to install a second set of projectors in their stock housings? Is it solely a matter of how/where the beams are pointed and maybe beam pattern, or is it also a matter of where they are physically located on your car?
Thinking of the retrofit, but I need to pass the state safety inspection in a couple months...
Ryd
Ryd
