How many people are looking for a lift?
I'm in for the downey coils, that include the rear coils and limiting straps, in addition to the the OME N86 Firm shocks. I still can't figure out what I'm going to do up front. All I do know is that I definitely want the revtek diff drop spacer too.
Chris
Chris
#25
Originally posted by phat4rnr
I am interested in the pp springs. Unfortunately, they say they are unavailable for 2002.
#26
Hey everyone, sorry I must have missed this thread...
As far as a group buy on OME, I would be happy to do it, however, you would literally save a couple dollars...Reason being is I am contractually obligated at this point to sell them for a fixed amount. ARB has finally put their foot down and have delegated the price at which we cannot go under.
I hope everyone understands that it is not my willingness to help, just my inability.
Always feel free to get in touch with me if there is something everyone is interested in, I will always do my best to help you guys out!
Regards,
Mike
Regards,
Mike
#27
That's understradable, Mike. I'm trying to decide what the optimum setup will be for me. I can't decide to go for the SAWS and Downeys for the optimal setup or save the money and go with the downeys and some OME shocks/springs in teh front? I can't decide yet, because I haven't read enough about the combinations and how they match up. I know I'm going with the Downeys and OME firms in the rear, and I'm buying them from you Mike, but as far as the front, I've yet to read enough about it, to decide yet. Any ideas or comments an anyone's current or previous setups would be greatly appreciated.
Chris
Chris
#28
Hey Chris, if you choose to run the Downey coils in the back, I would suggest using Bilstein Shocks versus OME...OME shocks are really designed to work with OME coils...Just a thought
As far as the front, I do not think you can go wrong with SAWs, however, they are fairly expensive...Your other option is to just do OME all around
Mike
Mike
#29
Mike, I really don't want to go with the Bilsteins because they aren't as long as the OME firms, and I want max flex in the rear and the front.
I don't think I can swing the SAWS, so what do you think is the next best alternative. I've heard that the medium coils are supposed to be mated to the comfort shocks and the HD's to the HD's. Is this true?
Chris
Chris
#30
OMEs are great all around just don't plan on getting a bull bar, otherwise you will get nose sag like i did and then want new coilovers. I speak from experience...
#31
I thought this would be a good thread to add this info in, but I'm a tad suprised at their response. Here's my email (thought it would be a great resource for anyone looking for a lift):
Please provide the fully compressed and fully extended lengths of the following shocks:
1) OMEN86 Rear Shock
2) OMEN86C Rear Shock
3) OMEN91S Front Shock
4) OMEN91SC Front Shock
Please provide the fully compressed and fully extended length of these springs, please:
1) OME880 Front Spring
2) OME881 Front Spring
3) OME882 Front Spring
4) OME890 Rear Spring
5) OME891 Rear Spring
This information is going to help me decide which shock/spring combination to run both front/rear of my 4runner. I've heard that mixing and matching the different firm and comfort shocks and coils isn't good, but is this true? I'm wanting the most articulation possible on my 4runner with a nice, slightly firmer ride that stock. I need 2" of additional height over stock to run my desired tire size.
Here's their response:
If you want 2" of lift, than OME isn't your brand. Our lift is only gives you approximately 1.25" of lift in the front and 2.5" in the rear. And if your wondering you can't use coil spacers with our system. If you still want the specs on our shocks, I will be happy to tell you. Thank you for you interest in our products and have a good day.
Best Regards,
Steven Bisig
ARB Tech Dept
ARB-USA
sbisig@arbusa.com
That seems really weird to me, and here's what I sent back to him:
[b]Yeah, I'd still like all the specs as I wrote if you don't mind. It would be really helpful in helping me make my decision. Also, people use spacers with your springs all the time with no trouble. Why do you say they shouldn't? Also, your springs are known to sag after a while, and I know the mediums to HD coils yield different rates according to multiple people that have them,
but I wanted to get the facts straight from you if you don't mind!
What do you guys think about his response. It sounds off on the front end, but I could be wrong. Then he says that we shouldn't use spacers in combination with their products. ???
Chris
Best Regards,
Steven Bisig
ARB Tech Dept
ARB-USA
sbisig@arbusa.com
Chris
#32
Here's the latest info from Steven at OME with more information to come:
Chris,
The reason we say no spacers, is that our springs weren't engineered for more than one 5mm trim packer (spacer)per side of the vehicle and we only recommend these if the vehicle is leaning to one side which is common on a lot of new vehicles with stock suspension. It is very rare for our springs to sag below there specification. In most cases when you install our springs
it will sit a bit higher than our advertised lift. After the driver takes
the vehicle out wheeling for the first time and flexes the suspension a great deal, the springs will settle. We experience a lot of people calling us complaining of there vehicle sagging when really the springs have just broken themselves in and are where they're supposed to be. For the front springs, the only difference is that the heavy duty springs (OME881) are a few millimeters taller to compensate for the added weight. Both the heavy
duty and light duty springs have the same spring rate.
Here is your requested information on our shocks:
N86/N86C 539mm (extended) 329mm (compressed)
N91S 470mm (extended) 335mm (compressed)
N91SC 470mm (extended) 335mm (compressed)
Hope that helps clarify some things. More information to come!
Chris
Chris,
Chris
#33
Here's some more info from OME:
Chris,
If you put the heavier springs up front and you didn't have a bull bar or winch then yes it would sit a few mm above the advertised spec. Although the truck would sit higher than what we advertise, it would not give a smooth ride that we are so greatly known for. As far as the rear goes, the heavy spring and light spring are the same height but different spring rate between the two. And unfortunately I cant disclose the spring rate information. I hope I have clarified this information for you. If you have
anymore questions please feel free to ask them. Have a great day.
This contradicts his last statement how the front springs are not a different spring rate, just the HD's are a tad bit longer to compensate for the additional weight. I'm waiting for a clarification.
Chris
Chris,
Chris
#34
Guest
Posts: n/a
I am also thinking of going SAW up front and putting a 2" spacer on top of the OME 891 on the back, that should give me total of 4" on the back and 2 3/4" lift up front with the SAWs crank up.
I like the hotrod look with the tail end sitting higher.
- Manuel
#39
mpampo,
Do you plan on doing a special diff drop or something?? How are you gonna handle all that lift, the front CVs will blow out in no time. You really shouldn't crank them over 2.5" of lift unless you have asin hubs. Some get away with 2.75 but much over that (with the diff drop) and your REALLY pushing it. Unless you have some new insight, please share!! I'm getting the 0-4" adjustable downeys, so I'm quite intereted.
Thanks,
Thanks,
#40
Guest
Posts: n/a
Or if you will be adding a bull bar, go with OME 882.
881 gave me an inch 1/2 up front.
I have the 891 out back and I got like 2", my '02 loks like a race truck but I like my ass end sitting higher. LOL.
I want more lift up front but I have no tools or have no garage to install a 1" cornbread spacer. Does any place like Midas install spacers?
