Last edit by: IB Advertising
- Toyota Tacoma How to Install Heated Side Mirrors<br>Step by step instructions for do-it-yourself repairs.
How to make heated rear view mirror?
I did a search and couldn't find any info on this subject. Did any 4-Runner ever come with this option? I had a Maxima with this option and they are great in the winter to get snow and condensation off. If this was an option on any Toyota it may be able to be retrofitted, but might be costly. Having worked in military avionics, we used Minco thermofoil heaters (www.minco.com) a lot. I think this is the type of heater that the heated mirrors have but maybe someone who has seen one can verify that. Does anybody have any other ideas of a small 12v heater that can be glued to the back of the mirror and is fairly cheep? Thanks,Chris
I assume you mean the side mirrors because if you had snow on the rear view (in the cab), you would reallly be screwed!
I know that this is an option that came with my 2000 SR5. Funny, I found out because I had the notorious warped driver side mirror problem and my dealership order a replacement. Then, once they started the work, they found that they had not order the proper parts for the heated mirrors and I had to come back another day.
I can't help you on a retro or anything, sorry!
Originally posted by jalaber
Heated side mirrors began in 1999 and was standard equipment on SR5 models and higher.
Any idea what it would take to fit a '98 SR5 to have the '99's mirrors? Would I have to replace the entire mirror and housing or just the actual glass/mirror section?
There is obviously already wires going through because of the power mirrors so I would see the wiring being a difficult thing.
Any thoughts?
Rick
Any thoughts?
Rick
Heating Steering Wheel?
Has anyone considered adding elements to make a heated steering wheel? How about heated seats (for those of us with non-heated seats)? I think I could retrofit those Minco units to my 2G mirrors. If I can only remember how they came apart (I replaced the glass on one before)...
Re: Heating Steering Wheel?
I'm not sure this link will work but its worth a shot.
[http://www.car-part.com/cgi-bin/search.cgi]What I found for 99 4Runner door mirrors.[/URL]
There were 5 different mirrors types on the 99 4Runner so with both sides there are 10 options. More to come as I investigate further.
There are manual and electric mirriors but no mention of heated mirrors. I assume the electricly aimed ones are also heated but I could be wrong... again. That would mean that you may have to buy the aiming control switches to make them work or maybe you can just swap the glass with the heat elements and keep the manual aim function.
Prices are everywhere from $64 to over $200 for later models. Shop around.
I can't link to my search results but there are several on car-part.com.
Thanks for investigating matt, I too am interested... I had them on my volvo and they were great! (my '98 ltd. does not have them, not that I was doubting J.A.!) As I was missing them in the recent ice storms!! and yes, the rear defrost was on... I would guess running the wires could be quite annoying, and if the parts are going to be toyota, ive got a feeling its going to be an arm or a leg, but... i'm eager to see what we can find!
They must have added them in 98?
Originally posted by Jason B
Jalaber, are you sure? I just talked to my buddy who has a '98 sr5 and his window sticker says it has "heated" side mirrors.
