How long do the stock rear springs last?
I just got a new to me 02, and the rear springs are a little saggy and im sitting about 1in from the cone bump stop and it bottom outs everytime i go over a speed bump. at 130k on the clock is it time to replace them?
You answered your own question if they are bottoming out.
I figure a bit over 100k it's usually time to replace them anyway but some can hold out longer especially if nothing was ever towed.
I had 100k when I decided mine were tired and it was the right decision at the time.
yep, sounds like a replaceme is needed! but just for the record, they can last much longer, as mine are the original ones and have 160k on them...previous owner never towed or off-roaded...
160k? I bet there'd be a big diff with new shocks tho'. My mom's '99 has 90k and has never seen off road or towed and mine with 30k on the OEM shocks feels much tighter.
Also new sway bar and steering rack bushings get tired by a bit over 100k too.
Ok well, will everything be ok if i dont replace them for a while? I have no money at the moment. Ill be towing a small waverunner trailer in a couple months thought.....that might be a issue.
I think you are fine. If you are worried about pulling your wave runner, just hitch it up and see where you stand. You need to remember your year of 4Runner sits the lowest. I do not believe you have a problem. If after you pull the trailer a couple of times and you think the ride could be improved, then go for it.
the thing that has me concerned, is if i roll over a speed bump, it comes down and bottoms out. If i stand on the hitch (~170lbs) its goes strait down to the bumps. There is literally 1/2in of up travel till it hits. is that normal? Im familiar with a 96 2wd and its got a few inches up travel before it hits. im going to go get some pics.
I would have to say that if standing on your trailer hitch bottoms you out, you definitely have to look into replacing those rear springs. IMO there is no way your weight should even have a noticeable effect, let alone push it to the max..
dude, are those pics with a trailer hooked up??? when i pulled a 4500 lb trailer worth of scrap wood to the dump, mine weren't even that close...and with no load, i know i'm a good 6 inches, if not more away from bumpstops...
well i got some 6 month old 97 springs and i put them in today thinking my springs where just sagging. Well i put the new springs in and they were good for about a hour then its back to the same way it was before. Any ideas? does anyone have any pics of their rear bumpstops on a stock truck?
