How is handling with 235/85/16's on 3rd gen 4runner???
Lets hear an update on 235/85r16s. I'm thinking about these Treadwrights now, as seen here as well https://www.yotatech.com/forums/f177...rip-ii-160254/
Quote from Expedition Portal:
Correct about the rubber content having to do with BFG not recommending the E tire for severe snow. Not they don't work in snow, but that there is a measurable difference in tire response in cold weather with cryophilic rubber compounds. Winter blend rubber compound also tends not to wear as well in summer and on abrasive roads as a rule, but so far I have had very good service from D rated BFG AT's in the same size as you are contemplating, and I could not say that they are wearing any faster due to the dual compound rubber. Driving on these tires so far includes a loaded trip down the Alcan in spring weather (no snow dry roads), so they have around 8,000 or 10,000 miles and you can still see the molding tits on the tread blocks.
06-01-2021 02:51 PM
jerusry
10-19-2015 06:28 PM
