How to get at top rear shock bolts
You can do what i did, so you can run normal eye and eye shocks.
I already did my shocks, but installed a 2" body lift just prior to the job. That allowed just enough clearance to stick a smaller size ratchet and a shallow socket in there. I don't know how it would be possible to do a quality tighten job without those extra 2".
By the way, your rear sway is going to fall off
I squeezed the heck out of the upper shock with a big channel lock and then used a ratchet with socket from the fender well. I think it was a deep socket I used and the ratchet fits perfect just above the frame.
I was going to pass this along to you folks who are considering a body lift in conjunction with a suspension lift. Do the body lift first, this makes replacing the rear shocks much easier!
Have a good week!
Brian
I have no body lift, and I think it took me all of 1/2 hour to get these shocks out, I cant remember exactly what I did, but I did not cut anything. There should be enough room, if you cant cut them out.
*EDIT*
After some thought...I think I did put the socket and ratchet in there, and just use the shock itself to work the bolt loose, just keep wrenching back and forth on the shock till that bolt loosens up, then, there is only just enough room to fit your hands in there to tighten the new shocks. Good luck
*EDIT*
#25
I will say that removing the rear shocks has got to be the worst job I've done on the 4Runner to date. First, I used a cut-off wheel and sliced into the fluid reservoir. Yuck! The sawzall did me right in the end and the second shock came off nice and quick.
MadCityRich
#26
#27
I used a flex end GearWrench on top & a pipe wrench on the metal dust cover. The GearWrench allows an allen key to tighten the top if you are installing Bilsteins. Big pain in the butt!!!
Paul
Paul
#28
#29
My skinny arms were able to form an 'X' at some point, at times just getting them past the sway bar, stabilizers, and other junk they would bend at humanly impossible angles. My fingers are not that long so I'm using my fingertips to create any torque to break off the seized nuts on the top shock mount. That and trying to squeeze my hand through any viable space to hold a measly little crescent wrench. Excellent forearm workout.
#30
[QUOTE=kmcaprice14;50867477] skip all the steps... just go straight to cutting it off...As for torquing the nuts, just hand tight using a small socket wrench with a deep socket... QUOTE]
Well, it was 1130PM when I had finally finished removal/installation. The fact that you can't see the top shock mount practically had me feeling my whole way through, so it didn't matter whether I had sun or not, screw it.
I'm stubborn and decided to go against the popular recommendation of destructive removals and got me some Craftsman strap wrenches. Low and behold...made it all possible to take off the old POS without damaging the housing. Someone earlier on this post 'wedged' one of the wrenches...that's what I did with the strap wrench against the muffler on the passenger side and the fuel tank on the opposite. Miracles do happen Worked so well that when I did the next rear side, I didn't use as much PB prior and still found it easier to break the seized nutcase.
Torquing the top nut, uh, yah, couldn't . Took a 3/8" breaker bar with a crow's foot attachment and with the other hand used a cresent wrench to grip that super small stud - slow as hell.
#31
I'm not so sure that is safe. The design Toyota uses is meant to pivot in more directions than the classic eye shocks can pivot. Maybe it's fine, but it looks like you've got a rigid mount where the adapter mates to the stock shock mount. That could be putting a lot of unplanned for forces on that shock mount area.
MadCityRich
MadCityRich
crashburnoveride
07-10-2015 06:39 AM
FS[NorAtl]: some RC stuff crawler and racer
akaphilly
07-09-2015 02:34 PM
