How does a normal 02 ride?
I bought my truck with 70,000 on it and I'm wondering if the springs are in good shape. The back end does seem to "wave," or "float" when going over larger humps in the road, and it slams sometimes, especially when going over speed bumps. Is this normal and if not, would new shocks help or would just replacing the rear springs with lesser used oem ones be good enough?
Originally Posted by Paul H.
Shocks are probably toast. if your springs are bad, your rear(truck that is) would be sagging.
Originally Posted by 4Runner4Christ
Agreed regarding the shocks. Although it's my understanding that the classic 4Runner rear spring issue was fixed back in '99. Your springs should be fine.
Originally Posted by ebelen1
What they did in '99 was add the cone under the spring so it doesn't bottom out as easily. This did not improve the spring characteristics at all. In '99 and '00, they actually put taller springs so you may have more of an issue with bottoming out.
The shocks are likely needing replacement but the 3rd gen 4runners have always had those characteristics when driving, just not as bad. The springs are the weak part of the design IMHO.
Location: Far western Kentucky (transplanted from central PA)
Both my 2nd gen ('90) and 3rd gen ('00) ride rough. I have Bilstein's on my '00 and it vastly improved the handling. The suspension is much tighter than with the stock shocks which is how I like it. You really feel the road. My g/f has a Grand Cherokee and she blasts me on how much "nicer" her Cheep drives (when it's not in the shop! ).
tazman1972
11
09-28-2015 10:32 PM
FS[PacNorWest]: 1987 4Runner SAS, 22RE, 5Spd, Dual Cases, etc
toyotasaurus
09-24-2015 03:30 PM
runnermedic
13
09-21-2015 05:20 PM
