How do you remove shocks? (Rears)
Just bought new shocks and I can't get the upper part of the shock loose! I have a strap wrench (cheap craftsman one) but no luck... are there any tricks?
I just did mine last weekend. A couple weeks prior, I sprayed the top nuts liberally with PB Blaster. Before putting a wrench on the nuts, I turned the shocks by hand to break up any dirt and crud. Then, I put my wrench on the nut and turned the shock's dust cover by hand (driver side) or by large slipjoint wrench (passenger side).
My forearms were sore for a few days afterwards though.
Getting the new shocks on and tight is harder IMO. Next time I do this, I'm paying the local Midas $89 to replace the rears (labor only). The fronts are MUCH easier other than replacing the springs. Midas will swap the springs onto the new shocks for $40. I'll pay the $129 to save the hassle of doing the rears and messing with the front springs.
Chris
Chris
You pretty much have to destroy the upper shock casing to get the stock ones off
Chris
I'm just glad I have a body lift on my 02 4Runner, otherwise I don't know how I would have been able to access the top nut for the rear shocks easily. It's a tough little bugger.
With that "strap wrench" secured around the upper most part of the upper shock housing & it's handle positioned against a convenient frame/chassis rail to prevent turning in the direction required to remove the upper nuts (there are two{2} by the way, that must be removed one at a time), I'd use the ratcheting 14mm to remove the upper mounting nuts (one at a time) & be done with it.
Hope this helps, good luck & post if you need help.
p.s. nice 'Runner, lucky you...& you've got an early model 'Crusier, too, now I'm envious.
Originally Posted by 89macrunner
did u try using a cheater bar?
Iceman4193
07-15-2015 04:48 PM
icentropy
07-14-2015 10:23 AM
FS[NorAtl]: some RC stuff crawler and racer
akaphilly
07-09-2015 02:34 PM
