How Do You Install a Metra Power Antenna?
Old 01-02-2014 | 04:57 PM
nstytop's Avatar
I have a '99 4-Runner. I've taken out the old antenna that didn't work and stopped making noise after about 4 mos. of slight movement and noise. I was thinking the wheel gears had smoothed out and not worth fixing. I bought a Metra power antenna. Took out the old antenna. Cut out the plug. There were 2 wires coming from the 4-runner a blue and a black w/ white stripe. I cut out the signal wire because I couldn't find the connection. I have an Alpine deck. I can't figure out what to connect to the wires coming from the 4-Runner. The 2 wires are 1-blue and 1-black w/ white stripe. The wires coming from the Metra are blue, red, black (ground), and black (signal). I don't know how to proceed and don't have the volt meter or that thing that you poke the wire to make it light up. Some help would be greatly appreciated.
File Type: pdf
tj884Rdlx
08-28-2015 01:04 PM
luckypig44
07-19-2015 12:25 PM
rushw
07-18-2015 02:46 PM
mlavery85
07-12-2015 11:33 AM
cars-guy
07-11-2015 08:51 PM
