How do you guys keep your engine looking clean?
Originally Posted by Vato Loco
Guess thats what California trucks engine bays look like! No salt at all! :p
I bought a bottle today and just got around to spraying some on my dash. I did just the top of the dash to see how it would be. I'm pleased with the stuff so far. Its not as greasy as "Armor All" is. Its also not as shiny which I like. There is such a thing as too shiny IMO.
I will detail the entire inside this weekend.
#25
Originally Posted by outdoorfever
wow those engines are so nice looking./ What is this foam stuff you guys are talking about?
#26
http://www.gunk.com/oe2.asp?pic=EB1
Gunk Foamy Engine Brite
http://www.gunk.com/oe2.asp?pic=FEB1
*NEW* Gunk Engine Brite Gel
http://www.gunk.com/oe2.asp?pic=EBGEL
#27
Once you have the engine and hoses cleaned I like to use something like Armoral, MaGuires or Mothers rubber, vinal leather cleaner on the hoses and anything plastic or rubber under the hood. They are all good products.
You can spray it on and let it sit and then wipe it off or use a sponge brush like I do . Just pour a little of your choice of protectent in a cup or small can and brush it on real good. That way you can get under the hoses and wires. Let it sit for a few minutes and give it another coat. It also really helps to use a spray wax on the firewall and finders. If you use the sponge brush you can reach the hard or hidden spots.This may seem like alott of work or over kill but the next time you spary off the mud and dirt it will just run right off.[IMG][/IMG]
#28
Well, after a few weekends of offroading/camping, I finally decided to show my engine some lovin'. I picked up a bottle of Simple Green and I went at it with a couple of different size scrub brushes (the old toothbrush was the most useful... it got into every crevice.)
I was very pleased with Simple Green. It did most of the work for me. Here are the before and after pictures of the engine.
#29
Be careful if your using Amor All and the like products under the hood since some ogf that can dry out rubber and plastic parts especially with the underhood heat and some of that stuff is bad news. Some company (can't remember right now) does sell underhood dress up sprays specifically designed for engine and associated parts use and I'd look into that before you use dashboard protectants under the hood.
#30
you can just use the engine cleaner setting at the car wash, then pressure rinse it. To make it shiny...get some armor all or other gloss protectant, and spray it all over everything, shut the hood and it will soak in witht he heat. then everything will look "bling". the problem is dust gets caught in it very quickly, I do it from time to time to keep the plastic and rubber parts conditioned but most of the time I just was it clean and let it be.
#31
#32
303 protectant is essentially Armour All. 303 was designed as an environmentally friendly, waterbased sunscreen for stuff. Namely for synthetics and composites used in the watersports industry (that's canoes and kayaks, not jet skis and bass boats). The stuff will prevent sun-fading and provide a nice greaseless shine similar to waxing. It even makes minor scuffs dissapear. Go ahead use it on your dash, leather, engine.
303 became hard to find when corporations bought corporations so I switched to UV Tech from McNett. Same concept and a bit cheaper. I seem to believe that the shine lasts a bit longer with UV Tech than with 303. Buy a gallon container of the stuff and with shipping it comes to about $.50 an ounce.
#33
Originally Posted by bob200587
armor all doesnt hurt anything, ive done it many many times and its fine, not sure about others tho.
#35
Here's a little tip when washing your engine. Keep the water out of the spark plugs!
The day after I washed my engine (covered battery and alternator with plastic bags, used garden hose to spray down engine and used simple green), my truck started acting really funny (misfire, wierd idle, CEL, VSC, and Trac lights on). I pulled the codes (P0300 and P0306). Turns out there was a little puddle of water approx 1/8" deep around the spark plug on cylinder #6. Wasted a couple of hours finding that one, but in the troubleshooting process, I cleaned the MAF and throttle body, and now it runs better than ever.
#39
