how do you check t-case fluid? (2nd gen)
how does one check the transfer case fluid..... also how is it filled if low?... sorry.... i've never tampered with the transfer case before....
im experiencing a small leak ..... one drop a day on the driveway.... so im thinking it must be getting pretty low.... want to make sure it doesn't run dry....
thanks for any help you can afford me
JQ
1993 4runner V6 4x4 (auto)
original owner, all stock except for Bilstein shocks and PP springs
JQ
JQ
JQ
Sorry I don't have any pictures of the plugs but they are at the back of the transfer case and on mine the fill plug is about 1/2 way up on the drivers side of the BACK of the case and it is a hex-head plug. The drain plug is near the bottom of the BACK of the case and is a allen head plug. If you decide to drain the t-case make sure you take the fill plug out before you take the drain plug out just in case you can't get the fill plug loose.
Ya use your dipstick. Noooo not that one...Your pinky.
Take the fill plug out and stick your pinky in. If it comes out with oil dripping off the end, the level is good.
jasonty
41
12-23-2018 01:00 PM
Poncho0206
07-10-2015 06:21 PM
Steezy96yota
07-06-2015 10:00 AM
