How do I remove or disable the factory starter disable?
Old 08-17-2015 | 06:08 PM
jmyer72's Avatar
I have a 2000 Limited. About 50% of the time when I try to start it the security light on the dash flashes and all it will do is continue to crank over but not start. Usually if I turn the ignition off, take the key out, then put it back in it will start. Every once in a while I have to do this a couple times.
I would prefer to just disable/remove the factory security and/or starter kill. I don't care if I lose the factory keyless entry because I don't have key fobs anyway.
Thanks for any help!
Old 08-20-2015 | 08:55 AM
RammerX's Avatar
You can just get another transponder key. I think your key may be bad or something. That's why the car won't allow the engine to start. ..
toyotamonster
3.4 Swaps
7
04-16-2020 07:02 PM
theking11863
03-19-2016 10:36 PM
clok
08-01-2015 10:42 PM
Hiluxtrucha
07-22-2015 11:00 AM
colinmil
07-06-2015 05:03 PM
