How do balljoint spacers work (and do they work on 4wd)?
Why all this talk about linear and non-linear travel with the two types of springs. From what I understand, both coil springs and TB's are are the same thing. They both use torque. TB's are just easier to understand. You twist the bar end of story. Now coiled springs work the same way. You are twisting the metal bar every time weight is applied. I guess it's hard to explain, but if you look at the springs as they compress, maybe putting marks on the sides of the springs would help, you are twisting the metal with each compression. So the same equation should work for both springs.
As for the "stretching" of a spring. Shouldn't be a problem. It just depends on how much force is needed to extend the spring and how much force the weight of the front suspension can produce at droop. If you can twist the TB in one direction to compress it, then you can most definately twist it in the opposite direction to extend it.
Math is one thing, but many of us have discovered that in the real world when you crank up the ride height with the tbars the ride gets harsher.
I suppose it doesn't change the spring rate (because theoretically it doesn't preload the spring?) but perhaps it affects the deflection rate somehow - which affects compliance? I can tell you that my F150 was getting a bit wallowy in the corners and I cranked up the front about 1" and it stiffened it right up, and I can tell you that I cranked down my Yota about 1" and it made a HUGE difference in compliance - it was harsh as hell and now the suspension actually soaks up some road variations and the ride is almost decent - it was amazing how big a difference it made.
Originally Posted by Flamedx4
That's what I was thinking, put those on and lower the bars down to the same height I have now, should ride smoother and flex better! I just might do this.
You will still need an alignment even running at the same height. Because the pivot point is away from the center, anything added to the end of the A arm will change the length. Just take a 12" ruler and set it flat on the table with one end at a fixed point. Then add a mount(yes "mount") a 1.5" spacer of some sort to one side of the ruler. You need to mount it so that it is flush with the ruler to be able to see that actual change in geometry. At the same ride height there, the ball joint won't be level, it will now be on an angle. That's why you will need an alignment afterwards.
Yeah, I know the geometry on steering axis inclination and caster lead and camber angle, and the spacer would change the angles but only a teenie bit. I wonder if it changes it enough to need realigned though. I suppose it comes under the heading of "better to do it and be certain..." *sigh*
#25
Originally Posted by OneTrickToy
Why all this talk about linear and non-linear travel with the two types of springs. From what I understand, both coil springs and TB's are are the same thing. They both use torque. TB's are just easier to understand. You twist the bar end of story. Now coiled springs work the same way. You are twisting the metal bar every time weight is applied. I guess it's hard to explain, but if you look at the springs as they compress, maybe putting marks on the sides of the springs would help, you are twisting the metal with each compression. So the same equation should work for both springs..
#26
ok... i read all the thread about the front of the truck with ball joint spacers... but what about the back since it is not independent suspension and has no upper or lower arms (or does ity and im wrong, its happened before) how doe that work?? or what do you do to the back to compensate for the front??
#30
Originally Posted by mt_goat
I'll repeat,"That's not to say something similar couldn't be designed to work on a Taco". Post some pictures of your front end, maybe we can come up with a new product.
#31
Originally Posted by superjoe83
you could put a ball joint spacer on a taco, but it would lower it, so it looks like drop bracket, coil over/spacers, and leaf springs are the only way to lift a taco/3rd gen
#32
So does the ball joint must attach to the top of the UCA on a taco? I'd still like to see some pictures or maybe I'll go to the Toyota dealer and look at one.
#33
I'm sure Frank will apprecate the helpful advice. He is a fulltime mechanical engineering student so I think SDORI is just a little thing on the side right now and having been thought engineering school myself, I'm sure he has little time right now for anything extra, like designing websites.
I'd have been online more but where the woman and I have been staying for the last few weeks has a dial up slowdem making the internet pretty slow and frustrating. As of Monday we'll be back on broadband.
Frank
#34
[QUOTE=superjoe83]the load carrying ball joint is attached to the lower control arm, so if you put a spacer in there it would lower the truck, theres not really a way to do it
[QUOTE]
Yeah, I see what you mean.
[QUOTE]
#35
Originally Posted by 914runner
OneTrickToy - Got any pics of the components of your 3" lift?
Thanks
Thanks
Road Bull
10-10-2015 04:55 PM
Suprarossa
07-06-2015 05:21 AM
